No Rotary (Leslie) Effect
I’m using ProTools LE Version 8.0.5 on a Windows XP computer with a Digidesign 002 rack interface. Most of my work is in standard midi files using a Yamaha Tyros 2 to enter the midi data and as my external sound module. So far I’m getting along fairly well with this setup. There is one troubling problem that is seriously affecting the playback quality of my midi files. I can’t seem to get any kind of rotary speaker (Leslie) effect into or out of my midi files.
I have enabled everything I can think of in Protools and in the midi options inside the Tyros 2. Some of the presets I use to enter midi tracks from the Tyros into PT have rotary sound as part of the patch while some of them allow me to trigger the rotary effect with a foot switch. As I’m playing I can hear the rotary effect switching on and off (slow-fast-etc.) as I monitor through the PT main output. Likewise, when playing one of the preset patches with the leslie programmed into it I can hear the effect through the PT main output. However, when I play the session that contains the organ track I just entered there is no rotary effect. Any ideas? Thanks, DVJ |
Re: No Rotary (Leslie) Effect
Well you could capture audio and avoid all the MIDI nonsense but sense you are trying to go the MIDI route.
It sounds like what you are hearing is the Yamaha controlling the Patch not the MIDI transmitted. This means that the changes you make aren't being recorded by PT so it can't play them back. What you want to do is have PT sit between the two stages of the Yamaha (keyboard Controller and Internal Sound Generator). To do this set Local to Off on the Tyros, this means you will have to route the control and MIDI into PT then back to the Tyros in order for the Tyros to play. Now PT will actually see what you are hearing. If you try to do this with the Local set to On it will create a MIDI Feedback Loop. When you want to use the Tyros without PT just set Local back to On.
URBAN MUSIC- (Hip Hop and R&B) |
I'll add 2 things. 1-by default, there are a couple of parameters that are checked in the midi input filtering box, so you might UNcheck those. 2-you could route your instrument thru to an AUX track and insert DB-33, which can be used as a Leslie sim(without using the organ part of it).
Rotary effect | MLE | Eleven Rack | 1 | 07-25-2012 08:27 PM |
DB-33 Leslie Control | JBRecording | Virtual Instruments | 2 | 04-25-2010 01:18 AM |
Leslie Plugin? | Tim R. | Pro Tools TDM Systems (Mac) | 3 | 05-18-2008 06:27 PM |
Leslie Simulators? | tg4878 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 02-01-2007 02:03 PM |
Leslie Effect Plug-In ? | Mount Royal | Pro Tools TDM Systems (Mac) | 7 | 02-25-2005 03:35 PM |
