Old 07-19-2022, 12:21 AM
LukeHoward LukeHoward is offline
Default Error finalising ADM WAV
Getting a frustrating error bouncing an ADM WAV which unscientifically appears to depend on routing and number of plugins. Appears with Hybrid Engine disabled and enabled. I'm on 2022.6 with HDX, MTRX clocked by Sync X, DAPS is connected via a separate MADI interface.
Generally it errors out finalising the ADM WAV and the logs are filled up with the following error. After the error occurs Pro Tools needs to be restarted. Bouncing non-ADM WAVs is fine. I eventually worked around it by simplifying the routing in my session, moving some prefader sends on some tracks to outputs (they previously had no output assigned, perhaps this confused something).
Edit: this workaround didn't always work, it appeared in simple sessions with almost all plugins disabled. It appears that there were many changes to the ADM bounce code in 2022.6 and this may be a regression.
Code:
2759.482711,51a03,0e0f: CMN_TRACEASSERT err == 0 /Users/autobld/gitlabci/PT/release/2022/r2/ProTools/AAE/Source/HostTDMDeck/CHostXDevice.cpp line 1875
2759.701733,101803,0b09: SLnk_UMEClock::UpdateRunningTime got a 0 running time!
2759.952474,101803,0b09: SLnk_UMEClock::UpdateRunningTime got a 0 running time!
2760.006766,51a03,0e10: FicOSErr: DAE Error being generated: -9004
Stacktrace:
	0x112eb98fa : FicOSErr(int) + 362 (AAE @ 0x112d9d000)
	0x112e591aa : CHostXDevice::ErrorCallback(int) + 266 (AAE @ 0x112d9d000)
	0x112e5aad6 : CHostXDevice::AudioCB_WorkLoop(CHostXDevice::CCallbackInfo&) + 198 (AAE @ 0x112d9d000)
	0x112e54dc3 : CHostXDevice::DoAudioProcessing() + 339 (AAE @ 0x112d9d000)
	0x112e59d27 : CHostXDevice::AudioCallback(IODriverAudioPB*) + 295 (AAE @ 0x112d9d000)
	0x112f10f8d : CBerlinIODevice::AudioCallback() + 637 (AAE @ 0x112d9d000)
	0x112f0fa94 : CBerlinIODevice::HandleAudioInterrupt(EDhmIsochEngine_InterruptMask) + 132 (AAE @ 0x112d9d000)
	0x112f0f779 : CBerlinIODevice::HandleInterrupt(EDhmIsochEngine_InterruptMask, unsigned int) + 697 (AAE @ 0x112d9d000)
	0x103f03ba3 : CDhmBerlinIsochEngine::IOBerlinDriverPrimIntHandler(void*, DSPRecord*, unsigned int, unsigned int) + 19 (DSI @ 0x103d5e000)
	0x103dac507 : InternalInterruptHandler(void*, unsigned int, unsigned int, unsigned int, unsigned int) + 23 (DSI @ 0x103d5e000)
	0x1015f9162 : CModule_Hardware_Imp::InvokeInterruptHandlers(unsigned int, unsigned int, unsigned int, unsigned int) + 108 (DigiPlatformSupport @ 0x1015f0000)
	0x1015f996b : CModule_Hardware_Imp::ThreadMethod(IPSThread*) + 391 (DigiPlatformSupport @ 0x1015f0000)
	0x1015faebb : CTask_Imp::MacOSXMasterThreadProc(void*) + 95 (DigiPlatformSupport @ 0x1015f0000)
	0x7ff81aa3c4e1 : _pthread_start + 125 (libsystem_pthread.dylib @ 0x7ff81aa36000)
	0x7ff81aa37f6b : thread_start + 15 (libsystem_pthread.dylib @ 0x7ff81aa36000)
2760.006846,51a03,0e0f: CMN_TRACEASSERT err == 0 /Users/autobld/gitlabci/PT/release/2022/r2/ProTools/AAE/Source/HostTDMDeck/CHostXDevice.cpp line 1875
2760.006943,51a03,000d: CBerlinIODevice::ReadSDIErrors() StreamingUnderrun
2760.006946,51a03,000d: >>> ReadSDIErrors failed with error code -9093
2760.203290,101803,0b09: SLnk_UMEClock::UpdateRunningTime got a 0 running time!
2760.453586,101803,0b09: SLnk_UMEClock::UpdateRunningTime got a 0 running time!
2760.455203,51a03,0e10: FicOSErr: DAE Error being generated: -9004
Stacktrace:
	0x112fa12fd : CFPGA_DMA_Device::TooManyIntsRecovery() + 205 (AAE @ 0x112d9d000)
	0x112f0fb08 : CBerlinIODevice::HandleAudioInterrupt(EDhmIsochEngine_InterruptMask) + 248 (AAE @ 0x112d9d000)
2760.455274,51a03,0e0f: CMN_TRACEASSERT err == 0 /Users/autobld/gitlabci/PT/release/2022/r2/ProTools/AAE/Source/HostTDMDeck/CHostXDevice.cpp line 1875
2760.704498,101803,0b09: SLnk_UMEClock::UpdateRunningTime got a 0 running time!
https://lukehoward.com/
Old 07-25-2022, 09:18 PM
Default Re: Error finalising ADM WAV
This appears to be a regression in 2022.6. I cannot duplicate it with 2022.4 or 2022.5.
Old 07-27-2022, 04:10 AM
Luke what computer/os are you running on?
Old 07-27-2022, 06:44 AM
2019 Mac Pro running macOS 12.4. Reckon it’s a PT bug though, I've logged a case with Avid and they are investigating it.
Old 08-14-2022, 08:11 PM
Essentially it boils down to this: no hardware inserts, everything is fine; hardware inserts on all tracks (two in my session), all fine; hardware inserts on some tracks and not others (two and one respectively in test session), issue triggered.
Transfer of Ownership Fail - Error: Error occurred while loading a Visualforce page Chevron Licensing & Accounts 10 12-19-2019 12:35 PM
Frame rate change after finalising TrentWilliams Post - Surround - Video 2 05-16-2016 11:55 AM
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error EricMulhern macOS 1 11-20-2011 05:39 PM
Error type 10,address error ,illegal error, buss error ,illegal instruction KasticK Pro Tools TDM Systems (Mac) 3 05-14-2003 11:21 AM
Buss error,Address error,ilegal instruction,error type 10 KasticK Pro Tools TDM Systems (Mac) 1 02-08-2003 05:49 PM
