Crash Upon Closing Session
I have a session that continually crashes when closing a session
Any suggestions? cheers PT 10.1.3 HD3 OSX 10.7.4 MOJO ProControl
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
Re: Crash Upon Closing Session
Try starting a new session and bringing in the tracks one by one and closing the session after each track. I had to do this and I put it down to a corrupt audio file. Once it crashes, you at least have a ball park as to what track/files might be at fault - consolidate that track to one new file and reimport and you should be ok. Its time consuming but worked for me.
thanks for your reply - I saw your thread, but there was never a follow up.
Will try that thanks
I get that a lot (in many sessions) and I always have to re-boot from cold. Other times (the same sessions) PT does not crash. I have no idea why this happens but I have a feeling that is related to how close to crashing due to "PT critically low on memory" one gets before the session is closed. So, if you are working and getting very close to "PT critically low on memory" (of course the user does not know that is getting very close to low memory) and close the session PT will crash. But if you just open the session, work a bit on it, and the close it, PT usually will not crash. At least this is how I am seeing here.
Hi Garnoil
You may have hit the nail on the head - my HD3 was maxed out and huffing and puffing with this 5.1 session. Can one affect the memory or is this stuck at the 2Gb limit until the doom of Pt11? (I say doom as it may mean new desk and hardware too for me). Adding more ram won't help nor will having a Kray supercomputer then either? cheers
We have to wait for PT11 to get rid of this problem. In my current project we are working on a HDX3 and have to split the movie into reels, because PT cannot cope memorywise with such an amount of tracks and automation over the length of the movie. HDX3 definitely needs PT11 to show its capabilities. For now the hardware is much more potent then the software is able to deal with.
MacPro 7.1 8c 3.5 GHz, 48GB RAM, HD native PT 2021.12.0, 10.15.7 www.imdb.com/name/nm0501611/ |
I had some problem with this, but now I use "free memory". It's cheap in the mac appstore and does a fantastic job.
I bought it when I noticed that sometimes Pro Tools forget to empty the "garbage" after the job. I'm not sure if this is your problem, but it seems that I have no problem since then.
my blog:Tamas Dragon |
HI Tamas
will give freememory a spin Thanks for the tip best
same here. PT10.2 - Lion - HD3
a lot of big crowded sessions open up fine but after make some changes and saving - when i close the session. PT crashes. if i don't restart i get a kernel panic every time. hope this gets fixed |
This problem is intermittent and hard to pin down
Freemem - whilst a nice app and usefull, does not solve the problem. It seems to be session related and to do with freeing the last dsp chip? Cheers
Crash when Closing Pro Tools 8.0.1 (every time) | AURORA4DTH | Pro Tools TDM Systems (Mac) | 10 | 10-25-2009 03:48 PM |
MPEG-4 (perian) movie causes crash upon closing the session | Sunzate | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-01-2009 10:16 PM |
ProTools Crash when closing | Marcus S. | Pro Tools M-Powered (Win) | 0 | 11-27-2006 07:36 PM |
Why does Rewire crash ProTools upon closing? | PastaViking II | Pro Tools TDM Systems (Mac) | 17 | 07-07-2006 06:10 PM |
Pro Tools v5.1.3 Crash When Closing Session | Chief Technician | Pro Tools TDM Systems (Mac) | 22 | 09-21-2002 03:17 PM |
