Old 03-07-2023, 07:26 PM
largoman largoman is offline
Default Undo "Split into Mono" :
I am well into a session. I hit split into mono Thinking only 1 track would change. All tracks then Split into stereo mode. Is there any way to undo this ? It cannot be undone Under the edit sign. Can I simply delete all the stereo tracks leaving just the 1 mono Track? Or will this mess with all the effects already Laid down. A dumb mistake I agree, but really need help with this. I would really appreciate any advice That could point me in the right direction.
Thanks any rans
Running windows 11Home. 12 GB (11.8 unable) 64 bit O.S. x64 bit Processor.
Just changed hard drive so plenty of storage.
Old 03-07-2023, 07:46 PM
Default Re: Undo "Split into Mono" :
I apologize for posting a thread I should have taken more time experimenting with. The problem has been solved. Since there was no automation on the stereo tracks added, I just deleted all of them And everything works fine. Again I regret posting something Prematurely.
Old 03-07-2023, 09:16 PM
nednednerb's Avatar
nednednerb nednednerb is offline
The visual cues to look for might be in the following workflow:
Am I wanting to perform one action on one track?
Yes, select the track...
Does the track name look like the one or two or more around it?
YES, then more than one is selected.
If so, command-click, de-select, re-check it!
Does the track name stand out as the only one like it?
Yes, then you probably have one track selected.
If so, you can still select one beside, then re-select,
just in case there is another one selected somewhere.
This used to get me a lot, haha, I find plenty of my attention with PT is spent NOT doing things on purpose, not only doing them with intention.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 03-07-2023, 09:30 PM
Thanks. I appreciate not getting slammed for that.lol. I believe a little more patience and practical thinking (like you mention) are in order for tomorrow.
Nothing but "Undo Change Control Value" in undo queue WinstonDeath Pro Tools 11 18 02-22-2023 12:45 AM
"Clip Slide" added to Undo queue in 2021.3 CarlosDanger Pro Tools 6 11-16-2021 06:43 AM
Vote for Ideascale "Edit Window Split View" reichman Post - Surround - Video 9 09-27-2017 08:51 AM
What are the difference between using a "mono" vs "mono/stereo" plug in on mono track rockguitarist1255 Pro Tools 10 4 12-07-2012 08:07 AM
What do i import a "dual mono" audio file as??? mono or split stereo? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-17-2002 04:02 AM
