Old 06-27-2021, 12:11 PM
taylor4814 taylor4814 is offline
Default iLok Cloud Session Activation Help
Confused about iLok Cloud Session activation... am I moving my Pro Tools licenses OFF my iLok to open an iLok Cloud session?
I have my Pro Tools license on my iLok; and have Pro Tools installed on several machines;
Is it possible to open a single instance of Pro Tools (not multiple, simultaneous instances) from the Cloud on a given machine, without moving anything off the iLok? (Such that when I go back to the machine where the iLok is, it works normally)
Old 06-27-2021, 12:36 PM
685 685 is offline
Default Re: iLok Cloud Session Activation Help
Yes. When you move the authorization from your iLok and over to the iLok cloud selection it will authorize and open on any computer where you have installed Protools. That computer needs to be connected to the internet and iLok will prop you to sign into your account. You can only use the cloud authorization on one computer at a time.
Old 06-27-2021, 12:57 PM
Ok, thank you.
Old 06-27-2021, 03:22 PM
Wait. I'm not sure the answer provided matches what the OP is asking. Once you move the Ilok authorization off the physical Ilok to the Ilok cloud, I think the physical iLok no longer works to authorize Protools. Therefore only machines using the Ilok cloud authorization can run Protools. If you plug the physical Ilok dongle into a non-internet connected laptop, it will not run Protools because the physical Ilok no longer has the authorization on it. At least that is the way I understand it.
To do what the OP is asking, I believe it is necessary to move the authorization off the cloud and back onto the physical iLok. Then move it back to the cloud again when necessary.
A better solution is to use the cloud authorization for all the computers (one at a time). Or just move the physical Ilok to which ever computer will be running Protools at a given time.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 06-28-2021, 07:12 AM
This^^^
The best solution is to take the iLok with you and use it to authorize whichever machine you are using. That's what iLok is made for. And don't forget to purchase Zero Down Time coverage and then turn on Theft and Loss Coverage.
If you do decide to go with iLok Cloud, you will have to either use cloud authorization, or move the license back onto the physical iLok, each time you want to use Pro Tools on that computer.
Also, keep in mind that the internet connection needs to be solid and continuous the entire time you are using Pro Tools with a cloud authorization.
Scott Gatteño
Old 06-28-2021, 07:30 AM
Right, to both, above...
How to activate Pro Tools Ultimate 2021.3 Subscription Bundle to iLOK Cloud Session? XJENSEN Pro Tools 10 07-14-2021 04:00 AM
Cloud Session instead of physical iLok the hecksome Pro Tools 2020 14 06-26-2020 11:37 AM
Error each time I open an iLok cloud session on a different machine techno_telemann Pro Tools 2019 1 09-24-2019 06:54 PM
iLok always opens cloud session PSCITR Pro Tools 2018 10 02-06-2019 12:54 PM
