Old 12-08-2016, 11:32 PM
Focuret Focuret is offline
Default No sounds from HD Native after switching user accounts (macOS Sierra)
Hey guys, back again with another question: when logged into one account with system output set to HD Native, everything is fine. But if I log out of that account and into a new one, I cannot get audio unless I restart the computer. Is this just the way it is or is there a work around?
I'm on a MacBook Pro with an HD Omni and Native.
MacBook Pro Touch Bar (15-inch, 2016 2016), 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3, Radeon Pro 460 4096 MB
Intel HD Graphics 530 1536 MB | macOS Monterey | Avid HD Native Thunderbolt | Avid HD Omni | Pro Tools Ultimate | Avid Artist Control | Avid Artist Mix
Avid Artist Transport | Genelec 8351b Monitors | Genelec 7360A Subwoofer x2 | Slate Digital VMS Virtual Microphone
Old 12-10-2016, 07:08 AM
Question Re: No sounds from HD Native after switching user accounts (macOS Sierra)
Are both accounts administrator accounts?
Old 12-10-2016, 08:33 AM
Default Re: No sounds from HD Native after switching user accounts (macOS Sierra)
Yep. It's really weird that just switching causes it to not work. It's recognized in the system sound output but there's no sound, not even on the Out meters on the Omni. If I want to get sound I have to restart.
Old 12-10-2016, 08:46 AM
Have you looked at the system.log file (/Applications/Utilities/Console) for any entries related to core audio when the problem occurs?
Old 12-10-2016, 10:57 AM
So it only happens when I log out of one user and then log into another user. If I remain logged into one user's account and switch to another, without logging out, it's fine.
I logged out before logging into another account to see and this is all that's in the log for CoreAudio:
Code:
	ASL Module "com.apple.coreaudio" claims selected messages.
Dec 10 12:49:18 ITAN-ABDULZ coreaudiod[242]: AvidCA_PlugIn::HandleConnectionChange. Component: com.avid.AvidAudioServer isConnected: 0
Dec 10 12:49:49 ITAN-ABDULZ coreaudiod[242]: AvidCA_PlugIn::HandleConnectionChange. Component: com.avid.AvidAudioServer isConnected: 1
Any ideas?
Old 12-10-2016, 11:28 AM
ITAN-ABDULZ is the name of your Mac.
It looks like its going from no connection (0) to connection (1). Why its not actually outputting audio is another matter.
This seems like a permissions issue. Is the user it works with the user account you used to install it? What happens if you uninstall it as the user who can play via CoreAudio, then install it as the user who cannot play via CoreAudio? Does the problem remain with the user who has the problem now, or does the problem switch to the other user?
Old 12-10-2016, 11:39 AM
Both accounts can play via CoreAudio. It's only when I log out of one account then log into another account that the audio ceases to output. For example,
  • The only user logged in is UserA
  • UserA logs out and is presented with the select user screen
  • I select UserB and log in
  • Now there is no sound output
At this point if I log out of UserB and then login to UserA there is still no sound output. I have to restart.
On the other hand, if the only user logged in is UserA and I don't log out but rather just switch and log in to UserB -- so now both users are logged in -- the audio still works. So there's some problem about logging out of a user account that breaks it.
Old 12-10-2016, 11:42 AM
Also, restarting the HD Omni, unplugging and replugging Thunderbolt it all different ways does not seem to help. The only thing that seems to do the trick is restarting the computer.
Old 12-12-2016, 05:41 PM
Arrow Re: No sounds from HD Native after switching user accounts (macOS Sierra)
Which is why I suggested installing it as UserB and seeing if the same problem occurs with UserA. It is either a permissions issue (UserB can't start it), an initialization issue (UserB tries to start it and fails), or both.
macOS Sierra Approved Jerry.VC macOS 9 11-04-2016 09:58 AM
S3L-x, PT 12.6 and macOS Sierra? HLD VENUE Live Sound Systems 0 11-01-2016 01:25 PM
PT on macOS Sierra? eesn Pro Tools 12 66 10-01-2016 11:46 PM
macOS Sierra 10.12 not yet supported Avid Technical Alerts 0 09-20-2016 10:34 AM
