Old 03-01-2013, 01:47 AM
c-post c-post is offline
Default best control surface for PT 6.4.1 please?
Hello ~
For a vintage PT 6.4.1 system with the expansion cards, etc, what is the most sophisticated Digi control surface I can run on that? Any control surface recommendations for this oldie but goodie? There's no way I could run a C24 or a tascam 2400 on that, is there?
thx
~ c-post
"TISH! You spoke PROTOOLS! Speak some more protools, Tish... disk allocation, degree of thinning, timeline insertion...ANYTHING!"
Old 03-01-2013, 06:52 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: best control surface for PT 6.4.1 please?
Originally Posted by c-post View Post
Hello ~
thx
~ c-post
I don't see any reason why you can't use a c24/control 24 or even the tascam. I'm sure the Avid one's would work just fine! unless PT6.4.1 doesn't have the drivers? but i'm sure i was using the control 24 with version 6, definitely 7.
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-01-2013, 09:07 AM
sunburst79 sunburst79 is offline
A Pro Control with the Edit Pack and some Fader Packs could be nice. I should note that I haven't used either personally.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 03-01-2013, 12:47 PM
Yeah, I'd say Pro Control(assuming TDM) or Control24(LE or TDM)
Old 03-01-2013, 01:25 PM
6.4.1 should be the final release for Mix. I'm guessing thats what the OP is using.
I was under the impression the PC would work with LE if one copied the controller profiles into the right folders. Again no personal experience here.
Scott
Core 2 Specs Page
Old 03-01-2013, 02:29 PM
I remember that being possible back in the day...but I'm not back in that day anymore. I also remember "TDMthang" that allowed you to run TDM software with LE interfaces(or something like that)....
Old 03-01-2013, 02:35 PM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is offline
Hello ~
thx
~ c-post
The most sophisticated Digidesign control surface you can run on PT 6.4.1 is a ProControl (with or without additional Fader Packs and/or Edit Pack). Next in line is a Control24, but it is no match for a ProControl. Both work by Ethernet, not by MIDI. Using the recent C24 is not possible.
Last in line are all the controllers that work by MIDI and support the HUI protocol, but you can't call that 'sophisticated' by any means
This is correct, and is still correct for PT 10 and PT HD 10.
Btw, all this info is by personal experience (see system details below)
Marc Schellekens
Delta Music Belgium - Dolby Atmos Music Studio
https://www.deltamusic.be
Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins
Old 03-01-2013, 06:56 PM
Craig F Craig F is offline
with HUI he could use the Slate Raven http://www.slateproaudio.com/products/raven/
but it is MIDI based
an old Pro Control is probably the best option
wasn't 6.4 when the D-Control came out or was that 6.9, no 6.9 was the D-Command
Thank you,
Craig
Old 03-02-2013, 10:42 PM
Thanks for the great suggestions. Ah the control24 is nice, but it's got a massive footprint -- too big for my studio, I've already got a digital console. I've been working with a c24 the last few weeks in another facility, but it also is a little too large for my studio setup. I love everything these devices offer, but why do they have to be so huge? Latching from one solo button to another with a mouse is too cumbersome, but using a c24 to do the same thing covers too much area. Sorry, I don't mean to be too finicky. Actually the tascam 2400 is closer to an ideal size.
c-post
[QUOTE=Delta Music Belgium;2012083]The most sophisticated Digidesign control surface you can run on PT 6.4.1 is a ProControl (with or without additional Fader Packs and/or Edit Pack). Next in line is a Control24, but it is no match for a ProControl. Both work by Ethernet, not by MIDI. Using the recent C24 is not possible.
Old 03-02-2013, 11:52 PM
Another blast from the past is the CM MotorMix. If one could scare up a MotorMate and join it to a couple of MotorMix 's you could have a pretty capable controller with a fairly small footprint. But its not a Digi interface however they may be the next best thing.
Scott
Core 2 Specs Page
003 control surface (As audio) & control 24 as surface crizdee ProControl, Control|24, Command|8 7 01-04-2016 12:30 PM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
D-Control Es32 Control Surface No Sound from Headphone outputs mark007 Pro Tools TDM Systems (Mac) 0 02-08-2012 07:03 PM
Digi 003 Control Surface Mackie Control Mode ctmusicman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-23-2008 07:23 PM
Mackie Control Universal or Tascam 1082 for control surface? anders Pro Tools TDM Systems (Mac) 5 05-28-2007 06:12 AM
