Pro Tools processing at 3db lower
Hi all
I've just started at a new company, and there's an issue with the main Pro Tools suite, where the programme is processing the audio 3db lower than it should be. For example if I import a reference tone which has been exported at -18 db, it will play out at -21 db. And if the clip is bounced down from Pro Tools, and then re-imported into the session, it will then play out at -24 db. I've checked the preferences etc within Pro Tools and nothing is abnormal, and if I play the clip via Premiere for example on the same computer, the original clip will play at -18 db as it is supposed to. Any feedback or ideas would be much appreciated. Kind regards, JJ |
Re: Pro Tools processing at 3db lower
Have you tried different Pan Laws?
Session Setup dialog. |
Thanks for the reply Drew
So on Nugen for example it's showing the "True Peak" to be at -18db for the individual channel, but the other stereo channel on Nugen, and the master channel it's being sent to are both reading -21db. However when I change the pan db in session settings to -2.5 or -6 for example it doesn't change the true peak or live peak at all. Panning it extreme left or right does... It's weird I don't want to necessarily by pass the -3 db panning setting (if I could), but we need to use the Nugen on the Master AUX stereo Channel, which is currently reading and exporting -3 db assumedly because of the -3 db panning settings, it's kind of a downward spiral in that sense |
Hi, welcome to the community.
It is exactly what a pan law is and works as it should
Recording Quality in Pro Tools Lower Than Logic | safehaven1017 | General Discussion | 17 | 11-09-2016 04:30 AM |
Pro Tools 11 processing vs MP9 | austinerary | Pro Tools 11 | 0 | 06-23-2013 11:54 PM |
Pro Tools 10 doesn't seem to like running at lower buffer sizes anymore | thegallowsindisguise | macOS | 4 | 05-11-2012 05:11 AM |
is 32-bit float processing available in NON-HD Pro Tools 10? | mixupandblend | Pro Tools 10 | 15 | 02-28-2012 02:54 PM |
M/S Processing in Pro Tools | The Mastering House Inc. | Tips & Tricks | 1 | 11-28-2006 11:50 PM |
