Old 05-28-2005, 02:49 PM
James Carter James Carter is offline
Default Midi out of sync with session
After upgrading to 6.9.2 all my MIDI was out of sync with audio in my session? Switching the sample/tick based timing didnt help! I still dont understand what that is by the way. Please advise
Old 05-29-2005, 08:28 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Midi out of sync with session
Hello,
What exactly has happened and how far and precisely is your midi out of sync?
Tick based means that the regions will be quantized and moved in relationship to the quantization! exactly how midi works, so you change the tempo of the session and all the midi parts move with the tempo change but stay in there relative places.
Sample based means that the regions won't move when a songs tempo is changed! they will stay exactly where they are!! and all the tick based stuff will move around them.
If you are using audio regions on your grid for example for say your cymbal crashes! if you change tempo and have them set to tick based, they will remain at the beginning of the bar, if they are sample based!! the bar position will move, but the cymbal being an audio region set to sample based won't move, and will then not be on the beginning of the bar! it will infact be playing out of time!
Hope this helps, check your tempo's
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-29-2005, 08:38 PM
Jan Folkson Jan Folkson is offline
You might want to also check to see if you switched from conductor based to manual tempo.
- Jan Folkson
www.janfolkson.com
Midi Timing Delay Sync Issue: MTC Sync daysean 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 01-22-2007 11:48 AM
QT bounces out of sync!!!!! but session IS in sync stormmusic Post - Surround - Video 8 01-12-2007 07:59 AM
Can Mbox sync to midi timecode or smpte sync? greeneye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-05-2004 08:47 AM
How do I sync my DM w/ my session jpoprock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-28-2002 09:44 AM
Sync Processor's Tremolo to Midi Time Sync via Interface j_jayzatuc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-01-2000 12:08 AM
