Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 06-20-2022, 04:29 PM
Armando Armando is offline
Default AAX DSP IR Cab Loader?
Hello? Not an owner(yet) just curious if there are IR cab loaders available for tracking with the Carbon/PT Ultimate combo. Thanks!
Armando
Old 06-21-2022, 02:18 AM
dominicperry dominicperry is offline
Default Re: AAX DSP IR Cab Loader?
bx_rockrack v3 from PlugIn Alliance, which is included in the Carbon bundle - (or at least it was when I bought my Carbon) - includes 40 IRs. You cannot unfortunately load your own.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 07-25-2022, 01:47 AM
martthie_08 martthie_08 is offline
I've been using AVID Space to load cab impulses
Old 07-25-2022, 02:06 AM
Avid Space doesn't work on Carbon, at least not as a DSP plug.
Dominic
Old 07-25-2022, 03:28 AM
what a shame, I assumed all AAX-DSP would work with Carbon, this is not the case though as you pointed out!
Old 10-10-2022, 12:15 PM
timsen timsen is offline
It is easy:
The question at least for "Carbon" is:
Is it possible to load IRs in the given latency from AVID (0,7ms) to take advantage of the DSP Processing in that crucial in-the-box guitar recording respect with live feel when recording and auditioning through software?
Does PT Carbon at all allow third party IR Loader with that announced latency or are there any dangers to know about (i.e.:
a) > 0,7ms,
b) compatibility issues,
c) any reported get no´s in deeper detail yet etc.)
What are your experienced monitoring latency measurements so far, if you use pt carbon´s internal chances for digital in-the-box guitar recording offerings?
I certainly would expect that AVID supports third party AAX DSP accelerated IRs with own import of your IRs as far as virtual instruments live recording with 0,7ms monitoring latency.
What does the ambitious latency info on the AVID site mean otherwise, if it´s not a overall value for a monitoring latency?
THX
T.
Old 10-11-2022, 01:39 AM
well, if it's possible with AVID's Space on HDX then why shouldn't it be possible on Carbon, which uses the same DSP technology (only less chips). I've done it on HDX and it works fine. It is still unclear to my why certain AAX-DSP plugins like Space are not supported on Carbon.
Imho a big limitation of the Hybrid Engine is the fact that you cannot mix DSP and non-DSP plugins. I have gotten so used to tracking DI guitars with STL's Tonehub which is only AAX-native with a AAX-DSP Trim plugin before it (latency is no issue at all) and miss that workflow in Carbon-land...
EDIT: I've only just now realised that you can take record-enabled tracks out of DSP mode... funny thing is though that the latency with Carbon is much higher as opposed to HDX with Trim and a native AAX plugin with both systems at the same buffersize (256 samples). The reported latency is worse btw on HDX but in reality is much lower.
In regards to mixing DSP and native plugins on the same track - it is possible, but only possible by loading the DSP plugins with the trusty old ICON D-Command. You still can't track through native plugins when in DSP mode, but you can take the load off of your CPU when mixing by instantiating available plugins on the Carbon DSP chips.
I suspect this is not intended by AVID but works nevertheless.
Old 10-15-2022, 04:32 PM
Yeah,
Is it like they managed in the box guitar recording somehow with cab simulation in 0.7 (monitoring latency) at least? Some AAX involved from any ! company. No problem accepting any AAX SIM, if necessary!!!
I' m confused with the announcements the more I hear in this regard
(0.7 in any case ) on carbon. Slight shiver here
... Or is 0.7 say - negotiable��?
Thx best regards
The diver
Old 10-16-2022, 05:35 AM
Originally Posted by timsen View Post
It is easy:
a) > 0,7ms,
THX
T.
No idea where the figure of 0.7ms latency comes from, but Avid's own testing shows bx_rockrack on Carbon giving 1.21ms latency at 96KHz, when using AAX-DSP.
Dominic
Old 10-16-2022, 05:45 AM
You understand that if you were to mix DSP and non-DSP plugs on a channel, then the signal would have to be processed by both the Carbon and the computer and passing the data backwards and forwards across a 1Gb Ethernet link would introduce even more latency?
Remember that USB 3.0, introduced in 2008 is 5Gb/s - five times faster than the Ethernet ports on the Carbon. The delay between the Carbon and the computer is the limiting factor. If you want low latency between guitar/mic/line input and headphone/monitor output, then it HAS to be done inside Carbon.
My suspicion is that they failed to put enough memory in the Carbon to run Space as a DSP plugin, but that is purely conjecture. Either way, and as expected, Avid's ambitions have not materialised. They have not given us Carbon monitor control from PT (although we did get pre-amp control). They have not given us a control panel or firmware updating tool which can be run outside of PT. They have not fixed Space to run on Carbon DSP. They have not found a way to make Carbon run on Windows (although I don't think they ever implied that they would do this). No sign of Surround monitoring either, or any use for the second Ethernet port. No HEAT in DSP mode. Most importantly they have not fixed the delay compensation bug(s).
Carbon is what it is. Don't expect anything which it doesn't already do.
Dominic
IR Loader w/midi control?? Armando AAX Plug-ins 1 11-09-2021 08:15 AM
AAX Guitar Cabinet IR Loader Howardk AAX Plug-ins 14 01-07-2019 05:02 AM
Digidesign Driver Loader Error! ciproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-15-2010 08:52 PM
RTAS VST loader? Bill0287 General Discussion 7 09-28-2009 12:35 AM
segment loader error pesedjet9 Digidesign Hardware & Software 0 04-10-2000 01:38 PM
