Old 11-30-2012, 06:18 PM
RichWilley RichWilley is offline
Default SampleTank2.5 plugins not showing up
Alright, I took some time off from Pro Tools 10 in Windows 7 (a few months, actually) and have now reinstalled it on a fast, new computer.
Everything is working great except that I can't seem to get the SampleTank 2.5 instruments to show up under plugins (that Inserts A-E thing).
I'm at my wits end It's hard to single out the right search terms to find this specific question on the forum, so my humblest apologies if this has already been covered.
Thanks in advance.
Rich
Old 11-30-2012, 08:37 PM
spenner spenner is offline
Default Re: SampleTank2.5 plugins not showing up
Assuming that you have the latest version of ST 2.5 installed and see the two SampleTank2 .dpm files in the Plugins folder... Are you trying to open ST 2.5 on a mono or stereo Instrument Track?
Old 12-01-2012, 05:44 AM
Okay, it was my fault . . . I wasn't using an instrument track.
But now that I've gotten SampleTank to show up, I can't figure out how to get the correct path so it will show my instrument choices. I don't remember having this much trouble when I did this before!
Thanks for your help!
Old 12-01-2012, 06:40 AM
Actually, ST 2.5 can be inserted on a Stereo Audio, Aux, or Instrument track. You were probably using mono tracks.
In ST 2.5 go to Prefs > Root > Browse then navigate to and select the path to the ST 2.5 Instrument folder. (If you did not change the default path during installation then it should be in C:/Program Files (x86)/IK Multimedia/Sampletank 2.5/Instruments).
Old 12-01-2012, 12:34 PM
And don't forget to do a relist in ST just to be on the safe side. You can also set ST to do an automatic relist on startup.
Old 12-01-2012, 02:04 PM
+1. Very good point.
Old 12-01-2012, 05:52 PM
You folks are geniuses! Thank you . . . it's working like a charm now. I really appreciate your help!!!
PT 11 HD with HDX plugins not showing up garnoil Pro Tools HDX & HD Native Systems (Mac) 7 09-28-2013 04:02 AM
New TDM Plugins Not Showing Up SPA Pro Tools TDM Systems (Win) 3 03-01-2010 06:07 PM
My AIR Plugins are not showing up! PUPO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-21-2009 04:41 AM
Plugins not showing up Royalston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-03-2006 01:58 PM
Plugins not showing up subaro0o 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-10-2006 12:25 PM
