Old 01-07-2016, 12:33 PM
alanc alanc is offline
Default PT 10.3.10 co-install with PT 12.3 Win 7
I am upgrading my system right now. Is it possible to co-install PT 10.3.10 with PT 12.3 on Windows 7 Pro 64? I would prefer to co-install instead of dual boot. Any problems I should look out for? Install PT 10 first? Delete preferences after 10 install?
Old 01-08-2016, 10:36 AM
Default Re: PT 10.3.10 co-install with PT 12.3 Win 7
Nobody co-installing on Win 7? The only info I have found has been for Mac.
Old 01-08-2016, 11:16 AM
astroturf astroturf is offline
You need 10.3.6 or higher. But ive silent installed v10.3.1 before with my 12 and it works fine. PM me for details because theres a few steps to it. Also on windows 7
Old 01-08-2016, 11:55 AM
Thanks, will do.
Old 01-08-2016, 12:02 PM
Works fine. Best I have found is to install 10 first, then install 12.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 01-08-2016, 01:02 PM
Thanks for the info guitardom. Thats good to know!
Astroturf, I will be installing the last version of PT 10 which should be 10.3.10.
Old 01-08-2016, 01:44 PM
check your pm. i think you should be able to install both without ahving to do any workarounds. Avid just kind of numbered their version weird, i thought 10.3.10 was equivalent to 10.3.1, since 10.3.10 is the latest im pretty sure you can just don a regular install of both. if not then message me.
Install PTHD 8.1.1 udater on Win7x64 and says valid install not found 8.0.3 is there rnygren Pro Tools TDM Systems (Win) 2 10-25-2014 10:58 PM
Mountain Lion/PT Install/Ilok install problems alex obradovic macOS 7 07-14-2013 06:19 PM
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions b-pole macOS 2 08-31-2011 07:23 AM
Can't install Pro Tools 8! Clean install, new system, Vista! DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 31 01-09-2011 11:16 AM
Can't install Pro Tools LE - Insert disc but no option to install Paul McConnell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-22-2010 08:13 AM
