Old 05-12-2011, 06:05 AM
oossyy oossyy is offline
Default recording vocals??
I'm trying to record someone's vocals and I just want to know how to set up headphones and speakers. how can you set them up so I can hear the recording through the speakers and the singer is able to hear the recording through the headphones at the same time??is this how you supposed to set up, to avoid the sound of the mix going into the vocals??
Old 05-12-2011, 06:08 AM
Default Re: recording vocals??
I should mention that I'm using pro tools 8 and a mbox mini
Old 05-12-2011, 07:19 AM
The Dougfather The Dougfather is offline
If your both in the same room and are happy with the same mix a budget headphone amp will suffice allowing you to mute the main monitors and both still be able to monitor through the cans.
Behringer do a cheapy for around 30GBP.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 05-12-2011, 07:31 AM
mindnoise mindnoise is offline
this should be best. Also Samson, Art and Lake People have nice, cheap Headphone amp/splitters too.
last: PT11.3.1
Old 05-24-2011, 10:06 AM
Talisker Talisker is offline
You should really find space in another room to set up the mic for the singer. Then you can still use your control speakers, use a extension cord to the headphone amplifier out of the Mbox headphone out. Also you should find a way to control volume without using the Mbox volume knob. That is how I do it and it works great.
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB
Old 05-24-2011, 01:24 PM
This is ideal, but you can do the job with a headphone "Y" cable so both you and the singer are on headphones(remember to not tap your foot.....). I find that if you have a mix going already that sounds reasonable, pushing the vocal track fader to +6 or so will make it sound good for the singer while they record. When you finish recording, drag the fader back down and add in your plugins as needed(I usually have an EQ for hi-pass, then a compressor, and an AUX send to an AUX track for reverb or delay(or both).
Old 05-25-2011, 03:09 AM
Or you can prepare two tracks, one is set up for recording with the right volume and a recording Reverb and so on, the other one has all the plug Ins, you want for your mix. So you record on the first track, then you drag the region right down to the "mix-track", so within a second you get to listen, how your vocal will sound in the mix.
Recording Hip Hop Vocals Matty503 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-20-2010 11:10 PM
recording vocals with 002 bigboi78 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-28-2007 12:38 PM
RECORDING VOCALS! dec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-16-2006 05:42 AM
Recording vocals 101 craig s Tips & Tricks 1 09-18-2004 07:16 AM
Recording Vocals Willie Baker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-08-2002 02:07 PM
