XP2500+ and OC or XP3000+
Hi everyone, I'm putting a new DAW together after the weekend and I'm wondering if I should take:
1. AMD XP2500+ and overclock if/when neccessary or 2. AMD XP3000+ Both CPU's have the same FSB, L1 and L2 cache's but the price difference is 200 USD where I'm located (150 USD for XP2500+ and 350 USD for XP3000+ believe it or not). I'm also wondering if Gigabyte's GA-7VT600L motherboard is good enough as ASUS mobo's are hard to find here in Iceland. http://tolvuvirkni.net/pw?inc=view&f...av=MOB_7VT600F The link is to an Icelandic website but there's a description of the motherboard in english. Any suggestions/comments appreciated. |
Re: XP2500+ and OC or XP3000+
To be honest, I have tons of processing power with the 2500. for the extra cash, I'm not sure it's worth it. 200USD is a good chunck of $$$!! In short, go with the 2500
How's Iceland this time of year? I've been there before. summer of '99. Nice place and cool people. Cheers ,Jayman#9.
Jayman #9 |
Oh, as far as the motherboard, it looks like it'll do the job. It has a Via kt600 chipset. It's the same chipset as my ASUS A7V600. Mine works fine, so I'm sure you'll have no problems. As far as I know, SIS chipsets are the ones to stay away from. VIA is pretty much a sure thing. But on the other hand, I hope I'm not wrong
Jayman #9 |
Thank Jayman, I'll go with your suggestion (unless someone else makes a case that I should not). I saw on the best system for under $1000 that this CPU (although with a different mobo than the one I'll get) scored 32+24 on theDAVEC test so I reckon I should be ok. Also, this will be a dedicated DAW so that should helpt too.
Iceland, as the name suggests, is cold and snowy at the moment, but I'll have my new system to warm me up over the holidays. Thanks again and best wishes. |
Digi 001, 002, or Mbox? Davec score may vary significantly with hardware and PT LE version.
Digi002R PT6.7 SP1 K8Vdx AMD643200 GeilPC32001G HitSATA80GB(sys) 2xSATA160GB GlyphXFW NEC2500DVDRW Sapph9600ProU SonyP234LCD AntecSonata Zalman7000Al |
More details about my future setup:
DIGI 001 PT LE 6.2 CPU: AMD XP2500+ or AMD XP3000+ MOBO: Gigabyte GA-7VT600F RAM: 1 GB (2 x (noname) DDR 512 Mb 333 MHz PC2700) HD System: WD Caviar 7200 RPM, 8MB buffer, 40 GB HD Recording: WD Caviar 7200 RPM, 8MB buffer, 80 GB HD Backup: Samsung 7200 RPM, 2MB buffer, 80 GB Screencard: Radeon 9200 SE 64 MB OS: Windows XP Home Then there's a generic case with a quiet PSU and enough space for additional HD's, a generic CD RW and floppy etc... Thanks for all your help. I've just been told that this CPU on this MOBO can not be overclocked, maybe I won't need to ?? |
The latest 2500+ Bartons are multiplier locked from what I read here:
http://www.overclockers.com/articles868/ |
Gleðileg Jól Bobbi
Excuse my English, I'm Icelandic. Vinnie Rocks!! |
Just picked up to a Digi 002R, still in box until my next DAW is built. Considered Asus P4P800 deluxe with P4 2.6 or 2.8 GHz 800MHz FSB until P4 config. disappeared from Best System for PTLE for under $1000.00. Now considering Asus A7V600 with XP 2500 or 2800+ Barton. What does the following mean in regards to performance?
Hey JamesV,
I also bought a Digi 002R, and I'm also waiting for my new DAW to arrive Asus A7V600 Athlon XP 3.2GHz 2* 512 MB PC3200 RAM I'll post the results of the DaveC test as soon as possible |
TRIED TO OVERCLOCK MY XP3000+ now it won't boot | powerjoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 12-26-2004 06:06 PM |
INSTALLED A NEW AMD XP3000+, BUT.... | powerjoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-11-2004 07:48 PM |
OT. problem with new AMD XP2500+ | northridgedave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-20-2004 03:17 AM |
AMD XP2500 | BEATS BY KP | Pro Tools TDM Systems (Win) | 1 | 02-01-2004 06:24 PM |
XP3000 Just Released From the Pen | Allen Hallada | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-01-2003 08:43 PM |
