Old 12-26-2007, 10:31 AM
plex plex is offline
Default Hardware Inserts in LE???
i've heard a few different things regarding hardware inserts when it comes to LE. First i was told that because of no automatic delay compensation - it is useless to mess with any hardware inserts because of latency. then i was told by someone else that this can be corrected with buffer settings???
i'd def like to use hardware inserts (like FATSO, DBX160's, etc.) shall i save my pennies for HD?
thanks!
003R, MacBook Pro
003/2.2GHz MacBook Pro 4GB RAM
Old 12-26-2007, 11:56 AM
Phil Ogden Phil Ogden is offline
Default Re: Hardware Inserts in LE???
Latency is reduced with smaller buffer settings but not eliminated particularly when additional A/D and D/A conversion takes place going to outboard. However, you could always try 'printing' the FX return (recording to a track) then nudging the region back to compensate for any delay.
http://www.myspace.com/philogg
Hardware insert 1&2 cutting off other hardware inserts on aux tracks Led Windows 4 12-09-2013 09:19 AM
Hardware Inserts trackone Pro Tools TDM Systems (Mac) 6 01-27-2012 06:22 AM
Hardware Inserts on PT 9 Obe1 Windows 0 06-09-2011 08:19 AM
Hardware Inserts CosmicJunkie Pro Tools TDM Systems (Mac) 1 11-20-2007 03:12 AM
002 Hardware Inserts tele_player 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-26-2003 11:02 AM
