Old 01-23-2023, 02:16 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Default Re: Crossfade not working
Originally Posted by izthewiz View Post
(default audio-suite preferences are create individual files / entire selection).
Set this to individual files / clip by clip. Set the handle length (bottom right) to something like 10 seconds. Now you will have 10 secs of handle length before and after your selection and you can make crossfades (of up to 10 seconds).
Note this setting will process/transfer your files before clip gain / clip fx. This is applied again after processing, but it might sound different during previews of RX. This goes for any audiosuite plugin.
Old 01-23-2023, 07:27 AM
its2loud its2loud is offline
Also,
Read up on handles.
https://duc.avid.com/showthread.php?t=323283
This is not an Izotope issue nor a Pro Tools issue, as others have suggested.
Old 01-24-2023, 11:44 PM
izthewiz izthewiz is offline
Thank you! This audio-suite setting for RX connect allowed crossfades between two rendered clips post RX processing. Although in this way RX audio suite has two seperate clips/files (left/right) for RX processing as opposed to a stereo clip. Not necessarily a bad thing. I'll keep testing this along with varying handle lengths, default is 2 seconds.
M1 iMac (2021, 16 GB)
macOS 12.6.2
Pro Tools 2022.12.0
Rme Fireface 800 V3.41
Old 01-25-2023, 01:30 PM
nednednerb's Avatar
nednednerb nednednerb is offline
Also check out page 168 and 170 or so of the Pro Tools Reference Guide (with 2022.12)
The "Interleaved" session options might be of interest to your workflow.
Used to be, PT was always multi-mono or separate L + R.
Since some time back, can go interleaved and use single stereo files.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 01-26-2023, 06:00 PM
I'll do some further testing with this. Thanks.
macOS 12.6.2
Pro Tools 2022.12.0
Crossfade not working jj5000 Pro Tools 9 0 12-03-2011 07:46 PM
Crossfade not working jj5000 macOS 0 12-03-2011 07:29 PM
Crossfade bug? Milanski Pro Tools 9 2 01-21-2011 10:26 AM
crossfade bug Steve MacMillan Pro Tools TDM Systems (Mac) 1 10-07-2006 09:51 PM
