Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 03-07-2022, 05:38 PM
Default Re: Loop Playback minimum now 1 second?
It may well be nobody's business, but often knowing why someone wants to do something turns up a solution not thought of
Old 03-09-2022, 02:12 AM
Noemie Noemie is offline
Originally Posted by BScout View Post
But a really easy reason is to find a glitch. Scrubbing doesn't always help in finding glitches but playback looping at normal speed does. You tighten the loop until it is only the glitch.
For this reason precisely this limitation is very annoying.
And also when comping really short notes/syllables that you have to chose between playlists.
Two cases where it wouldn't make any sense to copy+paste the section just to listen to it, total workflow killing with this workaround...
Old 12-07-2022, 08:00 AM
Maxwell1234 Maxwell1234 is offline
I've found that with a video enabled that the loop minimum is now 1 second where as with the video disabled it is the same old 500ms. It's a bummer because I don't want to disable the video every time I loop a syllable to EQ something out.
Old 12-07-2022, 02:45 PM
smurfyou smurfyou is offline
Yes I don't understand why there is a minimum threshold. It could be a minimum preference for people that aren't used to hearing millisecond loops but it should be possible if you want it.
The flaky video engine can't handle it. I'd be OK with it automatically playing with video offline if the loop is too short.
~Will
Loop Playback in MIDI = Loop Record? saspro Pro Tools 2019 2 04-01-2020 07:06 PM
Never Loop Playback Dibsy Pro Tools 12 8 02-09-2017 09:32 AM
Question about ProTools looping playback in timeline - minimum length required? natez311 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-21-2010 10:13 PM
Loop Record and Loop Playback will not engage? Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-28-2008 06:03 PM
