Old 11-27-2004, 10:21 AM
strider07 strider07 is offline
Default Sync to SMPTE timing issues...?
I guess I have brought this upon myself by upgrading to PT 6.7cs2 and Digital Performer 4.5 and using Mac OS X 10.3.6 (which, as far as I know, is not yet blessed)....
Anyway, If I setup Digital Performer to synch to SMPTE to play back a simple quarter note click and set PT to record in sync to SMPTE... then, record the same click track several different times on several different PT tracks, the location of the click events in PT can (doesn't always, but usually does) VARY.
I've been using PT and Performer for years. Never saw this before.
Performer is set to "MIDI ONLY". The MIDI interface is a MOTU MTP A/V (USB) with the word clock cable connected from the MTP to my 192. The setup menu has been set to many different settings without a different result... but right now PT is set to "no freewheeling" if that makes a difference.
Perhaps this would be better posted on the Post production section of the DUC. But, seems to be more traffic here.
Anybody got a guess?
Old 11-27-2004, 05:12 PM
Default Re: Sync to SMPTE timing issues...?
What's the master? DP or PT? I can't tell based on your terminology.
SYNC I/O SMPTE and PT9 help mgmazzei macOS 2 04-13-2012 06:20 AM
7.4 sync timing issues with Rewire, Guru, Battery, etc. Natas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-19-2007 07:01 PM
Midi Timing Delay Sync Issue: MTC Sync daysean 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 01-22-2007 11:48 AM
SMPTE RFI on Lip Sync Issues scott waz Post - Surround - Video 4 03-19-2005 11:08 PM
Can Mbox sync to midi timecode or smpte sync? greeneye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-05-2004 08:47 AM
