Old 05-31-2002, 12:28 AM
dj buttnaked dj buttnaked is offline
Default sample rate conversion
this may be a simple question but nontheless here it is. When trying to transfer ADATs at 48k to my pro tools session everything is cool until I mixdown and bounce to disc. When protools is bouncing everything is fine but when I downsample the tempo slows down. How can I rectify this situation. I am in need of someones help please. [img]images/icons/confused.gif[/img]
Old 05-31-2002, 02:07 PM
Jorge442 Jorge442 is offline
Default Re: sample rate conversion
<font size="2" face="Verdana, Arial">you{re sayign that when you bounce everything sounds fine, but when you downsample..........when are you downsampling? are you doing it outside of Pro Tools??
Did you set your PT session to 48k to begin with?
I use to have to switch my sync source from digital to internal (setups/hardware) sometimes when this happened......
good luck
jorge
what a long, strange trip it´s been
www.abacomusic.com
Old 05-31-2002, 02:09 PM
David Fisher David Fisher is offline
Sounds like something is just strectching it out to put the 48khz of info into 44... hmm
David Fisher
Berklee Student
Boston, Mass
Old 05-31-2002, 02:46 PM
thanks guys, I will look into it a little further. It is probably something that I am doing wrong.
I think I might need a sample converter of some sort before I burn it to CD ( any suggestions?) [img]images/icons/smile.gif[/img]
Old 06-01-2002, 10:36 AM
do you have an external (standalone) CD burner??
now go put some clothes on, boy!
jorge
www.abacomusic.com
Old 06-03-2002, 09:32 AM
no there is no stand alone cd burner everything is done internally. I think the problem was that the session was started in 48k both on the adat and on pro tools so when I bounced to disk everything was fine. But when I tried to burn to cd I forgot to change the sample rate.
Thanks for all the help.
Old 06-04-2002, 12:44 AM
bryanbassett bryanbassett is offline
I had this problem when I accidently Recorded realtime on the fly digital tracks recorded at 48k (Rolandvs880) into a PTle session via spdif..setup at 44.1 . When I noticed my error and reset the session to 48K the speed of the files changed so now i have this oddball session ..i'm not sure if 001 converted the files on the way in or not.
my thought is somewhere along the line you have a 48k vs 44.1k problem.
I would retransfer your ADAT files and make sure your session is setup at 48k..then when you mix and bounce to disk and select your output resolution everything should sound fine
Bryan
Macbook Pro Intel dual 2.4 OSX 10.7.5 Lion PT 9.0.6 Mbox Mini / 003R
MAC G5 PPC OSX 10.4.9 / PT 7.3 HD2 - I/O 192 /Control 24
DELL Dual Core, MBOX/003R PT 8 WIN XP
Old 06-05-2002, 11:47 AM
Thanks Bryan, I will take note of that in my next session. I will let you know how it goes. [img]images/icons/smile.gif[/img]
Old 06-05-2002, 11:53 AM
citi citi is offline
why do you need to change the sample rate at all? I burn 48khz file with no problem. On your bounce are you changing it to 44?
CiTi
http://www.checkonet2ent.com
Old 06-06-2002, 03:17 PM
eventually if you are planning on using anything on a cd the sample rate is 16 44.1k
Sample rate conversion? meathman Pro Tools TDM Systems (Mac) 10 05-19-2007 05:09 AM
sample rate conversion stickytapenrust Pro Tools TDM Systems (Mac) 1 04-25-2005 04:24 PM
sample rate conversion stickytapenrust 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-25-2005 02:20 PM
sample rate conversion D Clarkson Tips & Tricks 13 04-15-2003 10:38 AM
Sample Rate Conversion ThreeBlake 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-08-2002 12:55 AM
