Old 04-30-2009, 04:26 AM
JonesH JonesH is offline
Default D-Control channel mute/solo order
Hello,
I am setting up my first D-Control system as part of my vocational practice (I'm a sound engineering student) and we're of course using an X-Mon, wich the Pro Tools system interfaces with using an SSL Delta link/Alpha link-combo. This is run with an analog out to a Genelec AD9200 A/D Converter, to a 7270A and five 8240:s.
The Genelec system is happiest when fed channels in this order; L R Ls Rs C LFe so that is what I've done, and set up my I/O setup accordingly. Although panning and all aspects from Pro Tools work I still do have a problem with the output channel select/mute/solo buttons on the monitor strip.
They're labeled L Lc C Rc R Ls Cs Rs LFe, but they're controlling the channels in the genelec order (L R Ls Rs C LFe). Is there a way to set them up so that the C button controls the fifth channel (C)? Or do I have to simply re-label the buttons?
Thank you,
ICON Newbie
Johannes Oscarsson
Sweden
I just wanna do engineering...
(as opposed to make music :/ )
Old 04-30-2009, 05:02 AM
Drew Mazurek's Avatar
Default Re: D-Control channel mute/solo order
Just "crosspatch" them into and out of the X Mon so its happy and the switches work as labeled, but really you're connecting the interface and speakers as you want them.
www.drewmazurek.com
Old 04-30-2009, 06:26 AM
Yeah I figured that was the solution to go... But it's kinda too much hassle. But that's OK, it's just icing on the cake anyways, so if it's not possible to change it in the software we'll just let it be.
Send mute/solo follows track mute/solo pre-fader Roger_Jam_Jet Windows 3 09-24-2017 01:59 PM
certain tracks won't mute when I solo others? c-post Tips & Tricks 2 05-14-2016 04:54 PM
Can't solo or mute (bug?) mdb Windows 5 05-10-2013 10:29 AM
Protools 10: mute and solo aren't working. (Solo safe is not on any of the tracks.) charlottewrinch macOS 2 04-14-2012 05:32 PM
mute or solo bug? jpbm Pro Tools TDM Systems (Mac) 7 12-07-2004 01:29 PM
