Old 08-30-2018, 03:20 PM
Wave Mason's Avatar
Wave Mason Wave Mason is offline
Default Does Offline Bouncing reduce audio quality?
I am trying to bounce individual, raw drum tracks for an album. The standard real-time method will take a long time so I wanted to find out if there's a reason for this.
Is the audio quality the exact same when bouncing in offline mode over real-time?
If so, what's the purpose of the real-time bounce other than getting to listen through your track?
- Wave Mason
Old 08-30-2018, 06:55 PM
Sardi Sardi is offline
Default Re: Does Offline Bouncing reduce audio quality?
No.
Real-time bounce is essential if you use any hardware in your workflow.
Old 08-30-2018, 11:45 PM
Wave Mason's Avatar
Ok. Thank you.
Just to clarify, I'm trying to create WAV files of each track (Kick, Snare, etc)..
to put on a different computer for the production... What I didn't catch in your response is to Why is it essential to bounce in real time?
Does this render a higher quality sounding WAV file than when you check the "Offline" box?
Perhaps I should I be Exporting Selected Tracks instead of Bouncing them?
Old 08-31-2018, 01:13 AM
I did answer that.
It is essential if you’re using hardware processing in your mix. You can’t bounce faster than real-time if you’re going out to external gear and then back again can you?
Old 08-31-2018, 02:46 AM
Wave Mason's Avatar
But I'm not going back in again..
I'm not re-recording, bussing, or re-amping.
I'm not mixing. Simply looking to export the raw audio to Wav. in its least degraded method.
It creates the Wav fast when I do it offline. And plays through the length of the song when I bounce with the box unchecked.
Guess I should just copy the audio files directly from the sessions "audio files" folder.
Old 08-31-2018, 03:33 AM
Originally Posted by Wave Mason View Post
But I'm not going back in again. I'm not re-recording, bussing, or re-amping. I'm not mixing. Simply looking to export the raw audio to Wav. in its least degraded method.
Sure. Then bounce in non real-time or... commit the audio or... export regions as files. Many ways to do it that are NOT real-time and NONE of them will degrade the audio in any way whatsoever.
The reason I mentioned having to do it in real-time if you're going out to any hardware processing is because your very first post and topic title asks the questions... which I answered... pretty clearly I thought.
Originally Posted by Sardi View Post
No.
Old 08-31-2018, 08:09 AM
Wave Mason's Avatar
Thanks Sardi.
My apologies. You answered fine, I'm just dense as a brick sometimes. But I understand now and sincerely appreciate your responses.
Old 08-31-2018, 12:34 PM
No probs. :)
Commit Sound Quality - or is it offline bounce? JKR Pro Tools 12 4 11-09-2015 03:08 PM
No offline bouncing ??? maxon Pro Tools 10 33 11-27-2012 09:20 AM
offline bouncing? production Pro Tools 9 1 11-07-2010 09:07 AM
Lose quality by bouncing & then importing audio? brandin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-20-2005 10:11 PM
How to improve audio quality when bouncing tracks krhaarmeyer Tips & Tricks 1 12-31-2000 12:37 AM
