Old 06-08-2009, 09:23 AM
TXLefty TXLefty is offline
Default MIDI Control Surface compatibility
Does anyone have a Line 6 KB37 or other "generic" USB MIDI Controller working as a Control Surface in PT LE8? If so, how did you manage to set it up?
I am trying to use my Line 6 KB37 as a basic MIDI controller for a few simple tasks in PT LE 8. With KB37 connected, with no configuration at all it can already be used by PT to record MIDI Note data into a MIDI track. But I would also like to assign KB37's transport buttons and maybe a few knobs to control things such as PT transport buttons, a few plug-in parameters, etc. Seems like I need to set up KB37 as a "Control Surface" to do this. KB37 does come with a MIDI editor, so I can assign the type of MIDI messages sent from each button knob (MIDI CC, Program Change or MMC and their values).
I tried the steps in this support article, but no luck:
Basically, it sounds like KB37 (or any device that is not one of the devices found in the PT Setup > Peripherals menu as a supported Controller) can use the JL Cooper CS-10 Personality, and then configure the device to emulate a CS10. But when I select the JL Cooper CS10 Personality in the Peripherals menu, I have no option to then choose a MIDI In or Out port. Strangely, if I choose one of the other Personalities it DOES allow me to choose the KB37 USB MIDI In & Out ports for it, but of course it won't work since KB37 will not emulate one of the supported controllers
Thanks!
Old 07-12-2009, 10:36 PM
pabothecat pabothecat is offline
Default Re: MIDI Control Surface compatibility
Are you using Pro Tools 8? If so, they killed this functionality. Unless you have a JS Cooper cs-10, this preset will do nothing now.
Old 08-28-2013, 03:03 PM
rlameirasg rlameirasg is offline
I am also having problems setting up kb37 as a midi controller to use de soft keys as a transport controller any help? i am using pt 10, and already have set up a nano kontrol as if it was a maudio keybord mapping midi cc in the controller`s software but still want to use my kb37 as a transport control
Ricardo Lameiras
Recording Engineer
iMac 2.5 Ghz Inel Core i5 4GB 1333 Mhz DDR3 OSX 10.7.5
Protools 10.3.6
Avid Eleven Rack
003-Mackie Control surface compatibility earshatter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-20-2010 07:27 AM
Control surface - MIDI interface Freakybeatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-25-2004 04:28 PM
Evolution U-Control midi control surface eddie v MIDI 0 03-22-2004 03:53 PM
MIDI control surface Engramic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-18-2003 09:13 PM
need help configuring MIDI control surface for PC!! stilllearnin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 05-13-2002 10:59 AM
