  #31
Old 01-08-2019, 08:34 AM
off the wall's Avatar
Default Re: move multiple faders at once without having to group them first
Originally Posted by Norbertools View Post
It is maybe a stupid question, but how the heck can I move multiple faders at once without having to group them first? In Logic I choose the channel strips and move them at the same time. How do I do this in Pro Tools?
Group them and/or use a VCA.
offthewallproductions
  #32
Old 01-08-2019, 09:57 AM
Macsearcher Macsearcher is offline
It would certainly be great if the temporary group workflow that is available in some other DAW's was available in Protools.
I've just tried a setup that seems to work quite well for now.
Set up a group called TEMP and put it at the bottom of your group list.
Any time that you want to set up a quick and temporary group, select the tracks that you want, right click on the temp group name and hit replace in the group dialog.
It's far from perfect and a bit clunky but it does work.
  #33
Old 01-08-2019, 10:56 AM
Norbertools Norbertools is offline
Thread Title: "move multiple faders at once without having to group them first"
  #34
Old 01-08-2019, 10:58 AM
Originally Posted by wwittman View Post
That’s a group.
No, look at the video, I think you still did not understand it. Take your time.
  #35
Old 01-08-2019, 11:03 AM
To bring this thread to a conclusion, Pro Tools can't do temporal grouping. Let's hope that this essential feature will be implemented soon.
  #36
Old 01-09-2019, 12:34 PM
sputernz sputernz is offline
Originally Posted by yop22 View Post
I usually keep 2 or 3 "TEMP" groups in my sessions and I find the "replace" button (in the group dialog) quite useful to quickly replace the tracks included in the group with the selected ones.
This. And if you make a macro to make all your keyboard strokes and mouse moves it can be done even quicker. Just select your tracks, hit your predefined keyboard shortcut and boom, you got your self a new temp group.
  #37
Old 01-09-2019, 09:36 PM
wwittman wwittman is offline
Yes.
I have a Raven Batch Command set to do it.
but it's still just a temporary GROUP
William Wittman
Producer/Engineer
(Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!)
  #38
Old 01-09-2019, 09:37 PM
Yes.
Easy to make a Raven Batch Command to do it.
William Wittman
Producer/Engineer
  #39
Old 01-10-2019, 08:50 AM
Yes.
So you'd rather use 3rd party software to do what pretty much every other DAW can do natively?
(See also : MIDI -> audio, EQ Match, etc)
  #40
Old 01-10-2019, 12:33 PM
its2loud its2loud is offline
For any PT users out there who would like a "temporary group" feature, I've made a Mac Service called "Groups" that will automate the "Replace" feature when modifying groups.
When implemented, simply select the tracks you'd like temporarily grouped together and run the Service in the Services menu of the Pro Tools Application.
Alternatively, you can make a keyboard shortcut for the service using the the Mac System Preferences-->Keyboard-->Shortcuts tab. The "Groups" service will be in list towards the bottom under "General" See attached screen shot
The file can be found here...https://www.dropbox.com/s/cl6w0p3xut...kflow.zip?dl=0
simply unzip the file and put it in the folder "Macintosh HD">Users>"username">Library>Services
(replace "username" with your computer account login)
Restart the computer and the service will show up when you launch Pro Tools
Obviously, this isn't a perfect solution but it is a quick workaround for creating temporary groups.
One thing to keep in mind is the "Modify Groups" shortcut only works on the first group created in the session. Therefore, to make sure it doesn't change other groups in your session, make a "Temp Group" first in your session or template. Good luck. Hope this works for you
File Type: jpg Screen Shot 2019-01-10 at 12.20.54 PM.jpg (49.6 KB, 0 views)
Can you move multiple Markers as a group? amiller Post - Surround - Video 10 10-17-2013 03:28 PM
How do you Group AUX faders? ndaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-10-2006 09:37 AM
Making Multiple Moving Faders Group Jae Hwan Kim VENUE Live Sound Systems 1 06-07-2006 08:53 AM
How do I UN-group my faders? bH101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-03-2004 02:02 PM
Is it possible, move a fader group? tamtamstudio ProControl, Control|24, Command|8 5 12-16-2003 05:35 PM
