Bounce to Movie audio out of sync?
Anyone come across this?
When I play my QT movie, mono dialogue track and stereo music mix....all in sync. *BUT*, when I bounce those track to the QT movie, the result - a new QT movie - has the audio (notably the dialogue) out of sync with the pic. Ideas? thanks, b myers, composer
PTools 10.3.5, DigitalPerf 8.04, Sibelius 6.2, Mac OS 10.8.4 MacPro 3,1 8core 2.8Ghz, 16 Gig RAM, 4 x 120Gig hds, multiple LCDs Presonus FireStudio Project, MTP AV |
Re: Bounce to Movie audio out of sync?
YOu have to bounce at the same sample rate as the original movie. I have had this problem before as well. Sometimes it can also be that the movie in the PT session is in a wrong format.
I have had no problem with "Motion jpeg A" quicktime movies. But I am guessing it´s the sample rate thing ;-) |
Usually a sample rate problem. Bounce your movie with the same sample rate as your session and you should be ok, or check to make sure you're running at the same sample rate as the original movie.
hehe
Good point about the movie format too. Always stick with uncompressed DV movies, you'll have less problems over-all with that format. |
Quicktime movie bounce out of sync | SamZ | Pro Tools TDM Systems (Mac) | 6 | 03-19-2008 04:16 PM |
Audio doesn't sync to QT movie after bounce | KirinBenjamin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-18-2005 10:54 AM |
After "Bounce to new movie" audio is out of sync, any suggestions? | clusterer | Post - Surround - Video | 4 | 06-24-2003 10:46 PM |
bounce new movie, afterwards audio isn´t in sync | clusterer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-05-2003 09:38 AM |
Bounce to Movie Sync Problem | Matt87 | Pro Tools TDM Systems (Mac) | 4 | 05-09-2003 09:38 AM |
