Need help importing Final Cut 5 audio w/automation
The problem I am facing is that Final Cut 5 exports the OMF with completely unaffected tracks (no level automation or fades). I have been reading that with Final Cut you can also export the audio via XML, but Pro Tools does not understand the file. I did find a piece of software, XML Pro that will basically translate the XML so Pro Tools understands the file, but the software is $899.00. So I was wondering if anyone has encountered this problem and found a solution.
Re: Need help importing Final Cut 5 audio w/automation
I think you have found the solution. The OMF issue is a known and oft complained about issue. It's partly apple and partly that OMF is sort of a bare bones "standard" that doesn't require automation to be either exported or imported. THere are DAW's that won't import automation data in OMF's also.
SK Quote:
A question about importing OMF from Final Cut for audio sweetening | N8ty | Post - Surround - Video | 4 | 01-15-2011 08:47 AM |
importing audio from Final Cut Pro? | tonejunkee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-02-2008 02:43 PM |
Importing audio and video from final cut question | Tex Tiles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-12-2005 08:13 PM |
Need help importing Final Cut 5 audio w/automation | brockadams | Post - Surround - Video | 3 | 06-15-2005 06:50 PM |
Importing Final Cut audio into PT LE | Loftman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-02-2002 06:55 AM |
