Go Back   Avid Pro Audio Community > Dev > Pro Tools Scripting SDK Toolkit
Old 02-18-2023, 03:16 AM
LoTu LoTu is offline
Default Try Test The PTSLC_CPP
Hi all, can someone describe a bit more how to use the sdk ?
1: With the Cpp build
It seems I've built correctly the PTSLC_CPP.framework located inside the install folder following the python3 script -> running this command: python3 build_cpp_ptsl_sdk.py ptsl.client.cpp Debug
Then a new folder install was created: PTSL_SDK_CPP/install/Debug/PTSLC_CPP/PTSLC_CPP.framework/PTSLC_CPP and others files headers, Resources, Versions.
Ok then... I've created a new command line Xcode project just for testing...
I've add the PTSLC_CPP.framework ... but I've not found any way to include it in the main.cpp code...
2 With the gRPC proto stuff... What should I do for also test it ? I have no clue what to do with gRPC...
I someone has already a dummy javascript project example ? or any example project ... I think I'm close but I really cannot handle the inclusion or link the SDK files to any project.
Thanks for any help and advices.
Lo.
Old 02-20-2023, 04:27 PM
kenley_m's Avatar
kenley_m kenley_m is offline
Default Re: Try Test The PTSLC_CPP
Greetings Lo,
I think you should try out the example command line app included with the sdk. It's called ptslcmd. It should provide the missing context you're seeking.
In examples/ptslcmd/Source/ptslcmd.cpp you will find the main function of ptslcmd. Take a look there for an example of how to integrate the client library with your main.cpp code.
If you're familiar with cmake and would like an overview of how the app's project is put together take a look at examples/ptslcmd/CMakeLists.txt. Otherwise, you can configure and generate a platform specific project for Xcode [or Visual Studio] using the command below. This will allow you to browse the configuration via an IDE and see the ptslcmd code in context.
python3 setup/build_cpp_ptsl_sdk.py ptslcmd.sdk Debug
After running this command you'll find the generated Xcode project in the examples/ptslcmd/MacBuild subdirectory of the sdk.
Another PTLE Stress Test- "DaVerb Bounce Test" BioFeedback 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-11-2004 05:48 AM
digi 001 failed test 22 shared memory test the originalman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-14-2003 07:31 AM
Test 55 and test 123 in Digitest livearts Pro Tools TDM Systems (Mac) 1 10-11-2001 08:36 AM
test hkaufman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-06-2001 01:52 PM
Forum Broken test 1,2, test MacDaddy WGAR Pro Tools TDM Systems (Mac) 1 10-16-2000 06:56 PM
