  #41
Old 12-12-2021, 02:24 PM
tmuzik tmuzik is offline
Default Re: Dynamic Plug-In Processing is broken
I can confirm - Still have the issue with PT 2021.12 on stereo audio tracks - So the temporary solution is still to split to mono and treat session like an old (vintage) console.
I did find that using the "multi-mono" option on stereo tracks does in fact save approximately 40-50% in empty spaces - AND "multi-mono" plugins following stereo VI's save CPU as well.
EXAMPLE - CPU usage on stereo tracks on my test session
Plugin Modes
stereo plugins - 54% never off
multi-mono plugins - 54% - drops to 30% after about 9 seconds
mono tracks work perfectly and completely shutdown after 9 seconds-ish.
I did test stereo interleaved vs not and at 24bit and 32 float with the same results.
Hoping for a fix early next year... Avid?
Is it still on the RADAR?
Who is John Galt?
  #42
Old 12-12-2021, 05:29 PM
resonatee resonatee is offline
PT-279941. Did you file the support case?
  #43
Old 12-13-2021, 10:57 AM
My closed ticket displays "Bug Logged/Known Defect"
Who is John Galt?
  #44
Old 03-25-2023, 05:25 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Dynamic Plug-In Processing is broken [PT-279941]
This is now fixed in Pro Tools 2023.3 (see the release notes).
linkedin
  #45
Old 06-13-2023, 12:31 PM
I'd love to test but got off the support plan. Did anyone test it? Does it work reliably on old Classic Mac Pro 5,1 boxes? Thanks!
__________________________________
cMP 2 x 3,46, 128GB Ram
Monterey 12.7.4
Metric Halo 3d 2882 I/O
Lucid 88192 with Blue Sky 5.1 monitoring
10gbE ethernet with True Nas storage
Dynamic Plug-in Processing jkess Pro Tools 12 6 09-04-2019 12:35 PM
Dynamic Plug In Processing - 9173 etc. T-Low Pro Tools 2018 1 01-09-2019 01:22 AM
HEAT + Dynamic Plug in Processing in 12.6 T-Low Pro Tools 12 0 09-29-2016 12:44 PM
Dynamic Plug-in Processing Question quantise Pro Tools 11 1 03-13-2014 09:05 AM
Is Dynamic Plug-in Processing messing up some VI's Touchwood Studios Pro Tools 11 2 11-19-2013 02:09 PM
