  #31
Old 10-30-2021, 01:06 PM
K Roche's Avatar
K Roche K Roche is online now
Default Re: Dynamic Plug-In Processing is broken
Well dammm
I can report that on my system on 2021.7 DPP does not work on mono or stereo
I followed the menu in tmuzik post #27 and it did not matter mono or stereo the system usage meters stayed up while playing
I was on a 24 bit 96k session and I tried the Pro Multi Dynamics and then also removed that and did the Dyn3 Comp/limeter with D-verb and Tape Echo same same .. But this was a completely blank session (no audio)
I will install 2021.10 and try again
__________________________________________________ _______________________________________
Ok just got done installing 2021.10 and running test again
Here is what I found as per others
Works blatantly obvious on mono tracks
Works sort of but much less obvious on stereo tracks
Here is what did for the mono session
64 tracks 64 instances of Pro Multi Dynamics
I imported a short mono vocal section about 10 seconds worth, which I put on 32 of the 64 tracks
And placed it to start at bar 4
So start play back and system usage shows the same as at idle (about 2%) stays like that until the it hits the audio, goes up to about 25-30% AND as noted goes back to 2 % some 8 to 10 seconds after past the audio
Stereo session
64 Tracks 64 instances Pro Multi Dynamics
Import short stereo acoustic guitar vocal about 10 seconds on 21 of the audio tracks
Placed at bar 4
Idle shows 3 % hit play and it jumps to 38 to 41%. ---hits the audio goes up to about 48 to 53 % after it gets past the audio goes back to 38-41% or so after 8-10 seconds
Wonder WUWT ?????
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
  #32
Old 10-30-2021, 01:16 PM
Tweakhead Tweakhead is offline
what an awesome piece of detective work by tmuzik.
confirmed here too. mono DPP works, stereo doesn't.
although it takes a good 10 seconds after a clip ends for the CPU usage to ramp back down. seems a little long to have much effect on a real-life session.
  #33
Old 10-31-2021, 12:20 PM
Something else I just noticed . . .
If Tracks are muted, they still use DSP (mono or stereo)
ok, I can see that for fast manual unmuting of track mute switches I guess
but, if Clips are muted, they also still use DSP.
eg. if I have a guitar track for which I only use the solo section, I have to delete everything else rather than mute in order to benefit from DPP ?
c'mon now . . . that's just silly.
  #34
Old 11-04-2021, 01:49 PM
resonatee resonatee is offline
Acknowledged by Engineering Team as PT-279941. (Dynamic plug-in processing does not work on tracks wider than mono)
Please refer to support portal so we can have this fixed as soon as possible!
  #35
Old 11-04-2021, 02:26 PM
dominicperry dominicperry is offline
What kind of testing are Avid doing that means this is broken for ages, and when they finally come to fix it, they only check mono tracks? Absolutely scandalous.
Dominic
  #36
Old 11-04-2021, 05:32 PM
ZEUSS ZEUSS is offline
Dominic
What’s worse is it’s been broken for some time now! The OP brought it into more attention. Unbelievable.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
  #37
Old 11-04-2021, 09:59 PM
Yes, it seems the Pro Tools framework is pretty shaky. That's what you get when you have to hold on to years of backward compatibility, i guess.
Anyway, let's focus on solutions and escalate!
Anyone with a support plan, file a bug report and refer to PT-279941! They will fix it.
  #38
Old 11-05-2021, 11:51 PM
Rectifried Rectifried is offline
Bump this issue
Hal Cragin On the DUC Since The Year 2000 AD
Ventura ,PT 2022.10, MacbookPro 13"[2020] M1 16G, Antelope Orion 32+ Gen3..SSL Sigma summing, SMART Comp C1LA, CharterOak EQP-1 Oceanway Audio HR4S monitors . SSL X-Rack w XR618 compressors, dbx 160x [2]
  #39
Old 11-06-2021, 04:55 AM
which makes me think of the subject of renewals. mine is about to expire, and I am seriously considering not paying $400 for yet another year of updates which take one step forward and two steps back.
however this particular bug is such a major issue I feel that I am being goaded into renewing so that I can get a fix. I don't want to be stuck with my permanent license for what is currently a broken version.
this either already is, or could become a tactic for getting people to continuously keep paying for updates in order to fix various things that are endlessly broken/getting broken.
isn't there a law about this kind of thing ?
  #40
Old 11-07-2021, 05:21 PM
tmuzik tmuzik is offline
Hi Everybody,
I just want ask the members to please tap the brakes a bit and let's not let this thread turn into an AVID bash fest, pretty please.
I am soooooo glad AVID is addressing this issue.
We have all gotten along with it not working quite right for some time. So the fact that this is now being addressed is a giant leap forward.
Just an FYI another very popular DAW (Apple only) DAW has/had the exact same issue (I haven't checked the past few releases) - only their plugin issue effects the returns and not the tracks. No DAW is perfect, and that can be said with certainty.
On the bright side.
Because of this plugin issue, I fell in love with the classic, old and green McDSP plugins all over over again. The only thing they really lack is the harmonic content which can be added quite easily.
Since I moved to 88.2k and found this issue, my CPU got smacked pretty hard. I really did a lot of testing of plugin CPU efficiency vs sound quality to determine if all those extra cpu cycles were worth the result. Matching curves of eq and compressors, checking harmonic content with plugin doctor. Then bringing the matched settings into sessions and A/B-ing. It was quite interesting.... well... to me anyway.
Anyway, let's hope AVID get's the complete fix on the next release.
Looking forward to a great new year, let's not look backwards. Onwards and upwards.
Thanks Jeffro for expediting the issue.
Who is John Galt?
Dynamic Plug-in Processing jkess Pro Tools 12 6 09-04-2019 12:35 PM
Dynamic Plug In Processing - 9173 etc. T-Low Pro Tools 2018 1 01-09-2019 01:22 AM
HEAT + Dynamic Plug in Processing in 12.6 T-Low Pro Tools 12 0 09-29-2016 12:44 PM
Dynamic Plug-in Processing Question quantise Pro Tools 11 1 03-13-2014 09:05 AM
Is Dynamic Plug-in Processing messing up some VI's Touchwood Studios Pro Tools 11 2 11-19-2013 02:09 PM
