Old 06-03-2022, 04:45 PM
fork-media fork-media is offline
Default short cut key customisation fo time stretch?
Any one willing and able to take a look at the short cut key setting?
can you create a short cut for a specific tool now?
like a key for timestretch and a key for select object etc? ( i can sort of do it with keyboard Maestro ) but doing it inside protools would be great!
I'm on 21.12 and would like to move up if those things are working? dont have a lot of spare time but if it could do that I'd be motivated!
cheers
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive
Focusrite Saffire PRO 40
Ultimate 2022 10 / HD Avid MC Mix / MC Control
Old 06-04-2022, 03:47 AM
Default Re: short cut key customisation fo time stretch?
Near as I know PT doesn't do custom shortcut keys.
Jack
QAPLA!
Old 06-04-2022, 07:53 AM
its2loud its2loud is offline
cheers
Yes, in 2022.4 you can make a custom keyboard shortcut for the TCE Trim Tool and all the other tools.
Old 06-04-2022, 06:47 PM
Thanks! appreciated.
Old 09-04-2022, 03:36 AM
toppers toppers is offline
I'm also trying to make a better way to shift between timestrech and smart tool. But I'm having issues. I can't find a way to shift back to default smart tool, after using my custom SC for the timeshift-trimmer. Most optimal would be to just hold down a key to shift to the stretch tool, at the beginning and end of clips, but SC is the second best option and I still can't make that work in a satisfying way. Any ideas are much appreciated. :)
Mac Pro Early '08, 8 cores - OS 10.6.7
PT 9 Native - TC Studiokonnekt 48
Old 09-04-2022, 06:21 AM
Cheesehead Cheesehead is offline
You can do a timestretch/Smart tool toggle key with Soundflow., either as a keyboard shortcut, Streamdeck key or on a surface (Apple/Android)
I'm not sure what functionality you get with the free Soundflow that's now included with PT, but if you go on their site in the 'how to' section someone will get you going.
I guess it depends what version of PT you have if Soundflow is included?
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 09-04-2022, 05:42 PM
mattrixx mattrixx is offline
I do this with both a Streamdeck and via Eucon... oh and I also have it in Better Touch Tool.
Key command wise, you can string a macro together to go from the Smart Tool to change the smart tool to have the TCE active by entering,
Command 2 Command2
then to get back to the normal/standard smart tool with
Command 2 Command2 Command 2 Command 7
Hope that makes sense. (can happen instantly using a key macro).
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Structure Real Time Time Stretch FedericoF Virtual Instruments 3 02-18-2010 05:30 PM
How to Double Time (or Time Stretch) Midi? noharmlessrock MIDI 4 04-02-2008 07:32 PM
Time stretch? jimbojimbo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-21-2006 05:59 PM
Time Slice / Time Stretch on ProTools LE? Gilbert Espiridion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-23-2004 12:13 AM
Anyone know how to do this....Time Stretch... tomhartman Pro Tools TDM Systems (Mac) 14 10-06-2003 11:18 AM
