  #21
Old 05-07-2021, 05:01 PM
BScout BScout is offline
Default Re: Consolidating clips causes distortion
There's a bug in 2021.3.1/2021.3 where if you have a 32bit file in a 24bit session (whether you change the session bit depth from Session Setup or you import a 32bit file into a 24 bit session) and you consolidate, you'll get full peak distortion. I've reported it to Avid.
  #22
Old 05-08-2021, 02:26 AM
midnightrambler midnightrambler is offline
Originally Posted by daeron80 View Post
After opening his mp3s in RX, I doubt that's the problem. Unless he brought his master fader way down before bouncing or something. His peaks are well below full scale.
Originally Posted by Rich Breen View Post
Yes, exactly - unless this has been pulled down after the consolidate these files are at a very safe level. Something else strange going on with this. Would like to see the original files/session to see what's happening.
Not really - just because the mp3s aren't at full scale doesn't prove the original files on the track aren't - as you've both suggested the track could have gone through a master fader or some other sort of attenuation before exporting. As Rich says we need to see the session really, but from the info we have it suggests it's simply a problem between the 32Bit - >24 Bit conversion.
Edit : also just to say it took me about 30 seconds to be able to replicate this problem. (Turn the clip up beyond 0dBFS, still sounds fine on playback; consolidate, sounds awful)
  #23
Old 05-08-2021, 07:41 AM
Wow - hadn't seen that - good to know. Wonder if this is the OP's problem?
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
  #24
Old 05-08-2021, 07:47 AM
This forum is like screaming into the void sometimes
  #25
Old 05-08-2021, 02:46 PM
dominicperry dominicperry is online now
Where's Darryl when you need him? He's like an encyclopedia of these things.
Did someone upset him, or did he get Covid? Seems a shame that he suddenly went silent.
  #26
Old 05-09-2021, 08:06 AM
Don't know what other info you'd be seeking - until the OP either posts the actual session, or the files, or gives more information it's impossible to know, but BScout's post seems the likely explanation right now.
  #27
Old 09-27-2023, 04:27 PM
CBaudiopost CBaudiopost is offline
Hi there,
Did you ever get to the bottom of this?
I’ve run into the same issue. I work in audio post, I consolidate clips all the time and for some reason now when I do this, it clips the audio.
I’m having the same problem with audio suite plugins. For example I have a perfectly fine (not clipped or peaking) bit of dialogue that has a small mouth click. So I use RX de mouth click on 2 or so words and when I render it, those 2 or so words are completely clipped and distorting.
  #28
Old 09-28-2023, 10:12 AM
BLG BLG is offline
I think the answer is "You've pushed the file over 0dBFS. When you play this back through the 32 bit floating point mixer, it has enough headroom to cope, when you consolidate the clip to a 24Bit file, it doesn't.". The fix is either to lower clip gain (perhaps a lot) before consolidating or just commit the track which consolidates everything perhaps using a different process that doesn't do the conversion to a 24Bit. Not sure about that though.
Commit always consolidating clips? bing181 Pro Tools 12 20 06-01-2022 07:43 AM
12.8.1 bug: PT flips L/R channels when consolidating stereo clips in timeline Swedish Pro Tools 12 11 10-08-2017 01:23 PM
Commit always consolidating clips? firosiro Pro Tools 12 1 09-28-2017 12:52 AM
Consolidating Clips/tracks Tampaguitar Pro Tools 11 9 12-20-2013 11:33 AM
consolidating clips correctly..pls..help... chal7ds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-14-2005 12:22 PM
