Reason Adapted vs Not-Adapted...how does it work?
I'm currently using ProTools with Reason Adapted. I'm going to be switching a current project to a computer that uses the regular stand alone version of Reason with ReWire, and I'm not sure what the difference is.
Can you bring up Reason in a midi track just like you do in the Adapted version? How do you get Reason to play in sync and have the sounds play inside ProTools, is this part of the Reason/ReWire installation? Thanks, Arthur |
I have both 2.5 and adapted, both show up in Pro Tools as inserts. The main differnce is full Reason has a shed load more patches and more instruments. The signal routing is just the same.
Regards
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
Re: Reason Adapted vs Not-Adapted...how does it wo
I think the difference is that in Reason Adapted, you get a fixed "rack", whereas with Reason Non-Adapted, you make whatever you want. Files saved in adapted should open in "regular", though certainly not vice-versa.
MacBook Pro Core Duo 1.83 2 Gig RAM OS X 10.4.8 002R/PTLE 7.3.1 |
Reason Adapted lets you run 1 rewire stero-track, with the full version you can direct practically all your instruments to separate audio-tracks into PT in one take and at the same time you can listen to your reason Mixer as a sub if you wire it that way...
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8, Digi002 Fact., Logic X|FCPX|Motion Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix |
ugrading reason adapted 2.5 to reason adapted 3.0 | jimmyd3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-11-2007 06:10 PM |
Reason adapted does not work with Protools | benjaminblanc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 06-20-2007 11:52 PM |
Reason Adapted 2.5 to Adapted 3? | Phil Jeffers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-23-2007 09:00 PM |
Reason 2.5 Adapted vs 3 Adapted? | Simon666 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-09-2006 09:45 PM |
Reason Adapted doesn't work | Simpson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-12-2005 12:29 PM |
