Old 06-14-2002, 03:28 PM
Walling1 Walling1 is offline
Default MBox: No Sound Manager Input?!?
Has anyone been able to select the MBox inputs under Sound Manager? Is it even possible?
I'd be very annoyed if it can't...
Thanks!
-Dave
Old 06-26-2002, 03:47 PM
jes's Avatar
jes jes is offline
Default Re: MBox: No Sound Manager Input?!?
i just noguth the mBox yesterday and i am discovering this very problem today. this might make me return this thing. this is really pissing me off. i needed am I/O box that worked with PT and other things - i perform with the computer and that certainly doesn't involve protools ( i uses max/msp, supercollider and reaktor)
in fact i am also discovering that when it is used as the output of soundmanager, i can't use asio soundmanager in supercollider, it defaults to soundmanager as its driver, but with a buffer size of 2048 - which sounds like it's not what the mBox wants, it works for one cycle then spits out garbage.
i hate hate hate proprietary hardware. digi is really making me mad.
http://www.jonathansegel.com
Mac Pro 5,1 3.06ghz 64GB RAM
Macbook Pro 2.8Ghz 16GB RAM
PT 2022.10
UAD-2 Apollo Quad, PCIE and Satellite
Old 06-27-2002, 08:26 AM
DigiTechSupt's Avatar
-The Digidesign Control Panel only supports audio Output of Sound Manager through Digi hardware. As a result, MBox (or any of our other hardware) cannot be used as an alternate Input source for the Mac Sound Manager.
-Supporting the Direct I/O protocol is the only means by which third party software can access Digidesign hardware as both an audio input and output device.
-If your third party software is compatible with ASIO, you may download the Digidesign Direct I/O ASIO Driver here.
Brent
Avid Audio Tech Support
Support FAQ
Old 06-27-2002, 08:36 AM
jes's Avatar
jes jes is offline
this is maddening.
what is the point of making hardware that doesn't work with all apps? it would certainly sell more if it was more universal.
i use apps that recognize ASIO, but if i switch to the ASIO Digi direct I/O they can't load the Digi Init...
PT 2022.10
Old 06-27-2002, 08:56 AM
ckerian ckerian is offline
wow. I got over the lack of sound manager drivers under os9 2 years ago. I thought this was common knowledge. It pissed me off too. rendered (no pun intended) our aurora fuse card worthless on the new dual 800 g4 we got useless. sold the AM3 and said...screw analog video, went DV and havent looked back.
FYI.. you can route audio OUT the cards/mbox using the digidesign control panel. Just no input. Why? ask digi as it did work under os8.6
sound manager input impedence? beardeddubster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-01-2002 10:29 AM
How do I get input via sound manager? EnricoB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-29-2001 10:03 AM
usb input device that works w/ Sound Manager rossbf Digidesign Hardware & Software 3 03-24-2001 03:37 PM
sound manager / sound input / 001 lsr Pro Tools TDM Systems (Mac) 1 12-14-1999 01:58 AM
sound manager / audio input lsr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-13-1999 11:02 AM
