Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 01-29-2021, 09:15 PM
[email protected] headingnorth@outlook.com is offline
Default Surround
I realize that Carbon is not set up for surround monitoring. But it does have 8 outputs that could be sent as 7.1 to a monitor controller.
If I am using a Carbon with Ultimate software with the 8 outputs routed to my monitor controller can I still mix in surround? Or will the software be somehow be limited to stereo?
Can surround channels also be sent to the Carbon DSP? For example if i wanted to use the Carbon DSP on some surround channels to free up in computer DSP. Or do only Stereo AAX DSP plug ins work on the Carbon DSP?
And the next big question.
When will surround monitoring be implemented?
There must be demand from the music community this is aimed at to also have an interface for mixing in surround when needed.
Any input on this would be appreciated.
Old 02-05-2021, 12:12 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Default Re: Surround
Hello,
As long as you use Pro Tools | Ultimate you can mix in surround with Carbon.
Yes, you can use DSP on surround tracks.
I can't give an estimate on when support for surround monitoring control will be implemented, but it's on the list.
Hope that helps.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 02-05-2021, 02:24 PM
Thanks for this. It is helpful.
Old 06-30-2021, 05:09 PM
jallen01 jallen01 is offline
I am new to Pro Tools Ultimate and just going through the training however I am curious as to the set-up for doing this?
Can someone point me to some material as to how to set this up, or explain it to me.
Thanks in advance.
Old 07-05-2021, 03:54 AM
I have been doing more research prior to purchasing the Carbon and was wondering if I needed to add a surround monitor, like the Coleman Audio SR7.1MKII - Surround Level Control when using Pro Tools Ultimate?
I am new to Pro Tools and just setting up a system.
Old 07-07-2021, 01:59 PM
Hello,
Yes, that's correct.
Kyle
Kyle Splittgerber
Berkeley, CA
Old 07-07-2021, 03:13 PM
Thanks Kyle. I know that in one thread you mentioned that surround sound monitoring for Carbon was coming. I am sure you cannot answer when that will happen, but can you share if it's still on the horizon?
Old 10-16-2021, 07:45 AM
FrustratedLiquid FrustratedLiquid is offline
Just in case you have not seen this
http://dingdingmusic.com/-titles-/dolby-atmos-1.htm
Old 10-16-2021, 07:47 AM
Hello,
Kyle
Kyle, ive searched everywhere to find out what the word SUR stands for, located on the output strip on the Carbon. Is that what its for? Surround?
Old 10-19-2021, 09:26 AM
Hello,
We haven't announced what that's for yet, so I can't share any details.
Kyle Splittgerber
Berkeley, CA
Surround Panner for Surround Send in PT Control App tomaspal Avid S1, S3, Dock and Control App 6 08-15-2018 07:59 PM
Collaborating surround with non surround users/output issues emminova Pro Tools 2018 2 02-18-2018 09:57 AM
Ideal surround workflow with PT9 & 002 but no surround speakers? EricWillhelm Post - Surround - Video 5 11-16-2010 06:45 AM
SRS Circle Surround - Matrix Surround Troubles mrdale Post - Surround - Video 1 08-11-2006 02:12 PM
Anyone using Waves 360 Surround and/or Dolby Surround plug? Wheelieboy426 Pro Tools TDM Systems (Mac) 5 12-10-2002 02:13 PM
