Vertical Jumping With Edit Selection In Playlist View
This is my first post, and I've searched every keyword I can think of. So, I apologise if this has been covered elsewhere.
I have a drum group: OHL/R,SN,HH...RoomFar etc. I am in playlist view and currently track selecting. I only want to see OHL and the playlist tracks below. Does anybody know how I can prevent the edit window screen from jumping to the extremes of this group in the direction that I select towards? i.e. if I more the selection up, the edit window jumps vertically to 'OHL' (at the top of my group), and by the same token when I move the edit selection down the edit window jumps to 'RoomFar'. Many thanks to you all in advance! p.s. I hope my signature appears :)
PT10.2.0 Native | Sibelius 7.1.2 | OSX 10.7.5 | iMAc 27" 3.4 Ghz Intel Core i7 | 8GB 1333 Mhz DDR3 RAM | Digidesign 003 | RME Fireface 400 | Lacie D2 1TB |
Re: Vertical Jumping With Edit Selection In Playlist View
Preferences
Hi there,
thanks for that. I had already trawled through 'Preferences', and clicked most boxes that I thought were relevant i.e. I had already had a closer look at the 'Zoom Toggle' menu under 'Editing', and poked around in 'Display'. Do you have any specific path that you can point me to? Much appreciated, R
Shift+Command+G to disable groups, or you can disable just the drum group in the groups list.
Thanks again,
however, I don't want to disable groups: I'm track selecting/ editing. Any ideas? R
Haven't done that much editing and comping in playlist view, so I just made a selection across all playlists for one track, and hit "E" to "fit to window" (vertically). I constantly toggle edit groups on/off due to the way I have the preferences set up.
Oops, no... I hit Ctrl+Command+Up arrow, not "E" (Zoom toggle function).
Tired...
Yes, I can toggle my zoom by pressing 'E'. The problem specifically is that when I move a selection down to audition a new take/ section that the screen jumps to the extremity of the group. I just want to look at the top track and not constantly jump around.
I can send through screen shots/ video if this will help? R
Really? You compile without groups on? How should that work on a multi-track recording? Or do you mean you toggle groups on and off? This still wouldn't help my issue as I understand it.
I suspect I may not have been clear enough or, we are talking about different things. To be clear: I MUST have my groups active naturally to make selections for compiling or editing a group of mics that recorded one instrument (in this instance drums). I WANT to be able to look at ONE track only (for example the top track, which is in this instance 'OHL') when making these selections, regardless of whether or not I move my edit selection up or down (by pressing: p';l). Zoom Toggle Follows Edit Selection only zoom focuses my selection which is irrelevant for me. I just want visual stability and my screen not to jump around the whole time. I wonder if I can post a .mov on here, or a series of screen shots? Thanks for the input :)
playlist view still doesn't follow edit groups in Pro Tools 11 | jhamer | Pro Tools 11 | 4 | 01-24-2017 12:32 AM |
Plug automation selection jumping around | Newpostguy | Post - Surround - Video | 3 | 03-16-2011 11:05 AM |
How To Vertical Zoom Midi Regions View? | taylor4814 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-27-2009 08:00 PM |
Quick key for changing edit view to volume view in track? | postman56 | Pro Tools TDM Systems (Mac) | 4 | 11-30-2007 10:56 AM |
Edit Selection change w/ Undo/Redo Select Playlist | krofa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-24-2006 09:02 AM |
