.bwf from Sound Devices 744T
We did a 16mm film shoot where audio was recorded on a Sound Devices 744T as .bwf files. The post house doing the telecine needs a timecode dat instead, so I want to import the .bwf's into Protools with the original timecode stamp and lay back to a timecode dat. I can't get Protools to recognize the files at all. For Broadcast Wav, does .bwf work in Protools 7.2.1, or does it have to be a .wav instead? Any insight into how I might pull this off would be much appreciated!
Re: .bwf from Sound Devices 744T
Tell the Telecine house to work with the Broadcast wave files by renting the same recorder. You will spend way too much time trying to import files and then figuring out how to lay those off to DATS. This is something that should have been considered way before shooting.
Are all your dailies MOS, since they can't play the files? Sounds like you need to go to another telecine facility. What you propose to do is going to be a huge PITA! By the way, Pro Tools should be able to read bwf files just fine. Good luck with this.
Eric Lalicata C.A.S. Supervising Sound Editor Re-Recording Mixer Anarchy Post 1811 Victory Blvd Glendale, CA 91201 818-334-3300 www.anarchypost.net |
The standard suffix for broadcast wave is .wav. Just batch-change the suffix to .wav and PT should be able to import them. Many 744T users don´t know that the 744 will always record broadcast wave no matter how you set the suffix in the menue. The recent versions of the 744 completely dropped the .bwf option because it caused nothing but confusion. frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Just batch-change the suffix to .wav and PT should be able to import them. frank. [/QUOTE] How does one batch convert the suffix of many files. I have run into this problem before. I assume this is different from a Pro Tools batch convert. Buddy
PT Ult 2023.6 HDX2 Mac Studio M1 Maxx OS 13.2.1 64GB Ram S6 32 fader 2022.9 |
Just out of curiosity but why would the Telecine house need the audio? Are you having them put the audio and video together in the Telecine process? I hear this isn't a great idea on a regular basis. To just Telecine the video and relink the audio in Avid/FCP.
Buddy [/QUOTE] http://www.versiontracker.com/dyn/moreinfo/macosx/14404
Thanks Eric and Frank for all the info! I think the inital bwf's I got were corrupt. The data DVD I received with all the audio files(48k, 30fps TC) from the shoot imported fine.
We decided to skip the DAT and just import the files directly into Final Cut. I put all the files in a timeline(48k, 30fps) at their original timestamp and then imported the whole thing into a new 48k session @ 29.97fps, with the source sample rate in the import window set at 47,952. I then exported those converted files to the Final Cut editor, where he synced everything up to the video transfer. Seems like it worked fine. Thanks again for the help! |
[/QUOTE] To batch convert the suffix of many files in mac OSX: - open the folder containing all the file you want to batch, and be sure that is the floating open folder. - open the "Replace Text in Item Names.scpt" located in library script, - run the script - select file Names - write the text you want to replace ".bwf" - write the new text ".wav" - press Ok! beppe
Giuseppe MacBook Pro 17" 2.3 GHz Intel Core i7, 16 GB macOS Sierra 10.12.6 Pro Tools LE 12.6.1 modiomedia.com |
A good rename app which allows you to drill down folders. It works as a contextual menu item in the Finder. (Payware but it's relatively inexpensive):
http://www.publicspace.net/ABetterFinderRename/ A Better Finder Rename -jeremiah |
Sound Devices Mixpre-D | BRH | Third Party Interfaces | 4 | 11-22-2013 10:07 AM |
FS: Sound Devices 702 w/bag and kit | Audio_Vision | Buy & Sell | 0 | 06-28-2013 07:47 PM |
Tascam HS-P82 vs Sound Devices 744T | myke2242 | Post - Surround - Video | 7 | 08-28-2011 06:12 PM |
Sound Devices 744T files and post/Avid/FCP/ProTools | potatohead | Post - Surround - Video | 12 | 05-29-2007 12:27 AM |
sound input devices | Rottentom | Digidesign Hardware & Software | 5 | 01-20-2006 01:11 AM |
