Old 03-23-2011, 08:46 AM
Klosse Klosse is offline
Default Problem with Windows 7 64 bit / Nuendo 32 bit / EuControl 2.5.7
Hello!
I recently purchased an Euphonix MC Control for use with Nuendo 4.3.0. I have downloaded and installed the latest EuCon software (Version 2.5.7 for Windows 64-bit). The MC Control springs to life inside Windows and it recognizes when I switch applications. I am able to create soft keys for for example Firefox and save these.
However, I am not able to get it to talk to Nuendo. I have registered and downloaded the EuCon adapter to my eLicenser dongle and I have added it in the Device Setup within Nuendo. The Nuendo splash screen also says "Initializing: EuCon" when I start it. The soft keys update and the default Euphonix soft key setup loads, but after this, nothing happens. The faders never come to life and none of the soft keys or transport control buttons work. When I open up EuControl and open up the Soft Key Command Editor, it just gives me empty columns instead of the EuCon command hierarchy. See attached screenshot: http://i51.tinypic.com/2dc7lhv.jpg
Any ideas, anyone?
I am running Windows 7 64 bit, Nuendo 4.3.0 (32 bit) on an Intel core i7 920 with 12 GB RAM.
Klosse Wistbacka
West Bay Entertainment
Finland
Old 12-02-2011, 05:16 AM
Elmobe Elmobe is offline
Default Re: Problem with Windows 7 64 bit / Nuendo 32 bit / EuControl 2.5.7
I am having the same problem with eucontrol 2.6.2 and pro tools 9 HD. Eucoltrol is also loosing connection with my artist mix and transport all of the time.
Does anyone have the same problems ans knowns how to solve this?
Thanks a lot!
Chris
Old 12-07-2011, 02:50 PM
dpolcino dpolcino is offline
Well I had tons of problems the first two days figuring out how to set these up. This is only general advice, but I recommend turning off your firewall and antispyware programs, really make sure the Steinberg app and EuCon can talk to each other without running through some other software that checks what they're doing every second. When I did that everything started working on my setup.
digidesign 002r not working in windows 7 32 bit-Nuendo 4/cubais5 ahmedasbac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-08-2013 12:37 PM
EuControl kaput problem Xill Artist Series 7 03-01-2012 04:33 PM
Eucontrol preference panel in windows 7? Mark F Uk Artist Series 1 07-22-2011 10:07 AM
help with hd 7.4 - nuendo mtc sync problem peeweedrummer Pro Tools TDM Systems (Mac) 3 07-09-2009 11:34 AM
Problem when using Nuendo 3! kieuphucuong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-22-2008 03:48 PM
