Old 09-29-2017, 07:41 PM
Privyet Privyet is offline
Default Copying automation between reverb plugins changes values
When I attempt to copy automation data from the "decay" parameter of Dverb to the "time" parameter of "Reverb One", using Copy Special > Plugin Automation and Paste Special > To Current Automation Type, the automation data copies, expect that all pasted values are smaller than copied ones by 1.3 seconds. Acknowledging that these are two different plugins, the sound also clearly reflects shorter reverberation, weakly suggesting that this is not a purposeful reduction capturing differences between the plugins. The 4 starting and ending values in both parameters are identical before copy/paste. Any idea why this happens and how to prevent it? PT 12.7.0, very recent plugins. Thank you.
input numeric values for automation points sdigit General Discussion 4 04-03-2014 02:28 AM
Automation values fixed in 10.3.1 under ML? perh macOS 3 10-09-2012 05:55 PM
Volume Automation: Exact Values carterisgod41 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-10-2012 06:08 PM
Manually Set Automation Values f_zeus Pro Tools M-Powered (Mac) 1 09-12-2010 03:08 PM
Entering automation values?? Beyond The Pale 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-13-2005 08:23 PM
