Old 09-27-2012, 11:11 PM
Raoul23 Raoul23 is offline
Question Vocalign help
I've had Vocalign for quite a while now and I'm finding it to be a PITA and have reverted to doing things manually with EA but this is very time consuming.
What I'm asking is if anyone can help/explain what I'm doing wrong. Lets take this scenario for an example
I highlight the lead vocal section that I want the backing vox to line up with. Which say is 3 bars long. Press capture in Vocalign. I then highlight the backing vox line which needs to be corrected by Vocalign but this section is 3 and a quater bars long due to the backing vocalist holding the last note a bit to long and some of the phrasing is slightly out re the lead vox. So I press capture and I have 2 seperate wave forms in my Vocalign plug. I then press analyze it draws a wiggly line in the lead vox Vocalign window I then press process and bobs ya uncle then should both be in line, but no the backing vox part has got longer and worse than it was before Vocalign.
Am I doing something wrong here, any help would be much appreciated
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 09-28-2012, 12:24 AM
brickroadstudio brickroadstudio is offline
Default Re: Vocalign help
I have found that the regions need to be the same size. So, I would consolidate them both into new regions of the same size. That seems to solved the weirdness that sometimes happens.
Also, dumb question, but when you select the bg vocal, are you hitting "dub" first?
Old 09-28-2012, 12:47 AM
Yep I'm hitting dub when I do the BG vox. So if I want Vocalign to shrink a vocal I need to select a bigger region from the lead vox line even if there is no vocal in in some of the section
Also is there a way to select a certain amout of a wave then move down to the next track and have exactly the same amount selected in that track?
Raoul Crane
Old 09-28-2012, 12:30 PM
danms66 danms66 is offline
That must be your issue right there. You should always use the "p" and ";" keys when selecting these edits.
Old 09-29-2012, 05:55 AM
Make sure you have your handles set to 0. Do it in the prefs for best results. I use vocalign LE and don't really expect to see any updates for it to work w handles. Bit this will throw your timing off big time.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 09-29-2012, 05:10 PM
Cheers guys ill be testing tomorrow
Raoul Crane
Old 10-11-2012, 02:55 AM
Havent tried the Handles setting that guitardom suggests. i tried to use it on a session last nite and it totally went strange i made sure the regions were exactly the same size the singers were even singing the same line i just wanted to tighten the vocals up. clicked process and it made the "DUB" track short and all out of time
It wouldnt even let me capture a region, after about 5 mins it locked up and wouldnt work. Its driving me insane!!!!!
Found out they have an update out to the one i have installed. I'll install it and see what happens hopefully this will fix it
Raoul Crane
Old 10-11-2012, 05:30 AM
Get the update and you must set the handles to 0, preferably in the prefs before you launch it, not a suggestion, it's necessary.
pro-tools-pc.com
Intel I7 9900k
Win 10
Old 10-11-2012, 10:25 AM
Installed new update and set handles to 0 and everything is work great. Cheers everyone
Raoul Crane
VocAlign Project vs. VocAlign Pro apoc64 Post - Surround - Video 3 02-27-2012 10:53 AM
vocalign kidboy500 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-30-2010 11:08 PM
Vocalign LE with PT HD 8.0.4? sean shannon Pro Tools TDM Systems (Win) 18 08-15-2010 05:47 PM
VocALign Pro Or VocALign Project? Mark 66 Post - Surround - Video 3 09-18-2006 09:05 AM
anyone using Vocalign with PT 6.1?? A2D D2A 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-01-2003 11:41 AM
