Re: Getting Spectrasonics Trilogy to work in PT LE 8
You don't need any wrapper, it's native RTAS on a PC, just make sure you install all the correct components and upgrades.
I work with amazing people who do incredible things. Founder of the Expert Sites. |
Try going into the used plug-ins folder and manually typing ".dpm" as the suffix. That solved the problem for me.
used plug-ins folder ? where can I find that ?
HD/Applications/Digidesign/Pro Tools/Used Plugins
#16
Ok, found it. But there are no files with the name "Trilogy" or "Spectrasonics" in it. Which file am I supposed to rename ?? Seems like every plugin has a .dpm and a .dpm.rsr file....
#17
the plugin is installed system drive/library/app support/digidesign/plugins Chris
#18
no no...I'm on PC....but it doesn't seem to install rtas....just vst...and the vst can't be wrapped by the fxpansion wrapper.
Spectrasonics TRILOGY | Friend | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-17-2008 10:16 AM |
Spectrasonics Atmosphere / Trilogy | GORILLA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-26-2007 06:09 PM |
Spectrasonics Trilogy | Flpalla | Virtual Instruments | 5 | 04-01-2007 02:18 PM |
Spectrasonics Trilogy | Larry Younkins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-13-2005 09:08 AM |
Spectrasonics Trilogy | Pase | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-22-2004 11:45 PM |
