Can\'t create fade files (only)
After installing a second HD for Protools sessions, I get the following message when trying to do a crossfade (strange syntax and capitalization is per the message box):
Could not complete your request because You do not have appropriate access privileges (-5000) while creating "0534_continuity" while creating "Fade Files". 0534_continuity is the name of my session. I can record and Bounce to Disk (in both Audio Files and Fade Files folders) on this drive. Permissions are Read & Write for both me and the group, and I am the owner of the drive. This seems to only affect creation of fade files and I do not have this problem when working on my system drive. Any ideas? Thanks in advance. |
Re: Can\'t create fade files (only)
Try using the OSX Disk Utility to repair permissions on your primary hard drive.
Also - was the drive formatted using the OSX Disk Utility? |
Thanks for the suggestion, but Repair Permissions did not fix it. (The sessions are on a slave drive that does not have OS X installed.)
However, File > Save Session Copy In..., then copying everything to a new session did fix it. I wonder if I will have to do this will all my pre-existing sessions? |
Fade editor problem in PT8 (create Fades, command-F) | Aski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-19-2009 08:51 AM |
Synchronizing Fade Files/Audio Files (Task Window) | rtcstudio | Pro Tools TDM Systems (Mac) | 1 | 04-23-2009 10:52 AM |
Can't create a fade anymore during playback on 7.4cs2? | lastminute | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-15-2008 08:48 PM |
Can't create a fade | mixit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 12-10-2004 06:13 AM |
Can't create a fade out | Ferna | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 07-23-2003 07:01 PM |
