Old 08-31-2021, 02:38 PM
jkd62 jkd62 is offline
Default GUI short freeze and beachball still on 2021.7
When i updated to 2021.6 I got the wellknown short freeze Challenge several times each your (maybe 15-20 times pr hour) I tried to solve the issue but ended up downgrading to 2021.3. Then everything worked perfect. Then came 2021.7. I hoped it was fixed. But it is exactly the same problem. Is there anybody who has had the problem and fixed it ?
I am using: Mac OS Catalina 10.15.5
3,4 ghz quad core Intel core i5
24 gb ram
Radeon pro 570 4 gb
Old 08-31-2021, 08:15 PM
Default Re: GUI short freeze and beachball still on 2021.7
I don't know if this is a fix or not, but a couple of us did a clean install of the OS (in our case it was Big Sur) from scratch (not factory install). Then a fresh install of Protools 2021.7 (not upgrade) and have not seen the freezes or beach balls. Given that each user has different plugins, it is not clear if a certain plugin is possibly causing the freezes or beach balls so YMMV. If you have a spare SSD and the time, it might be worth a try.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 09-01-2021, 01:24 AM
Emi's Avatar
Emi Emi is offline
Works fine on M1 Mac mini. No beech ball for now.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 09-01-2021, 04:42 AM
ejsongs ejsongs is offline
Short beach ball is driving me crazy.
Ej
5,1 2010 Mac Pro
3.46 12 core
64 gb ram
Radeon 580 gpu
10.4.6 Mojave
Hdx in magma eb7 châssis
Old 09-01-2021, 06:40 AM
its2loud its2loud is offline
Really? I constantly get the beach ball
Old 09-01-2021, 07:56 AM
audiogamble audiogamble is offline
There are some people here who will tell you to reinstall your OS. It doesn't fix it. I tried. Running an M1 macbook air.
There's at least one person here persistently telling people to do a clean install on the basis that a theoretical test-session recording blank audio works fine. I think in reality, those tests doesn't correlate with how people actually use pro tools. In my experience, the problem seems to be triggered by scrolling around in a larger session. GUI/meters gets sluggish, and eventually beachballs. 2021.7 is better than 2021.6 for this, but it still exists.
I'd strongly recommend to disregard the suggestions that a clean install will fix 2021.7 . You'll likely commit to a lot of downtime with no results to show for.
Submit a support ticket to avid, and wait for the next PT update which hopefully fixes it once and for all.
Old 09-01-2021, 10:20 AM
Eric Lambert's Avatar
They are reporting their real-world experience so the info is valuable. But, yes, it's not been stated, and probably not discovered, exactly what it is within those reinstalls that fixed the issue for their particular system. I do agree that a full OS reinstall is a bit extreme, but it's a process that has worked for some -- it's up to each individual to decide if it's worth the effort.
Old 09-01-2021, 02:38 PM
Thanks all
A clean instal which might/might not work is to big a mouthful at the moment. I will downgrade once again to 2021.3 and finish my projects. I have just paid nearly 400 euro for my license and honestly I feel bad about not being able to upgrade for the money I’ve paid especially when it’s an issue that apparently hit a lot of Pro Tool users. I will submit a support ticket and hope it’s fixed in the next version.
Old 09-01-2021, 02:48 PM
climber climber is offline
If you are running any background network tasks I would disable them. Just sayin…
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 09-01-2021, 10:42 PM
Thanks. Tried it but no difference.
Commit / Freeze / Rendering Tracks causing Pro Tools to freeze or crash iamkimosabi Pro Tools 2020 11 09-02-2023 09:09 AM
2021.6 and 2021.7 restart after exit NJsound.com Pro Tools 12 08-11-2021 01:45 PM
Short graphics / system freeze PT 2018.12.0 Win 10 and Nvidia GT 1030 sdi Pro Tools 2018 0 02-04-2019 02:51 PM
OT: The short (or not so short list) of... badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 02-05-2004 05:38 PM
