  #21
Old 12-06-2013, 04:27 AM
tristan klein tristan klein is offline
Default Re: Mavericks has broken Eucon....
hey all.
As I worked with FXpansion on a few things for BFD3, my old 2009 21,5 iMac was not powerful enough to handle PT11 and BFD, even with 16 GB RAM.
so I bought a brand new 27" iMac two weeks ago and now I have the same issues that you guys mentioned and showed on youtube.
so this is clearly a maverick compatibility problem ( as everything worked fine on moutain lion ) and I am sure AVID team is working on it.
www.tristanklein.com
  #22
Old 12-15-2013, 04:15 PM
DanielEUCON's Avatar
DanielEUCON DanielEUCON is offline
Anyone using 10.9 needs to disable App nap for all Eucon related apps.
Select the application (EuControl) and right click > get info. Here you can disable App Nap.
Do this for Pro Tools, Logic, Cubase, etc etc etc. also.
App Nap causes all sorts of issues. Not just Eucon related but across the board for Mac Apps
  #23
Old 12-15-2013, 04:53 PM
trock trock is offline
thanks Daniel
any word on when it will be fully supported though?
thanks
PT 10 - Mac Pro Octo 2.8 - 10.8.3
Artist series - MC control v2 - 2x mc mix - mc trans
Apogee Symphony
  #24
Old 05-10-2014, 11:04 AM
jacko's Avatar
jacko jacko is offline
What if checkbox "prevent..." is missing?
It doesn't show up in get info window of eucon app. It shows up with different apps though...
UAD Apollo x16,
UAD Apollo Twin Duo,
UAD Octo Thunderbolt,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Arturia Beastep for DAW control,
Former Pro Tools HD user (from V7 until V12.6).
  #25
Old 05-10-2014, 03:22 PM
AlienArtist AlienArtist is offline
I posted a likely solution here ...it should at least allow us to use the Artist series until an official fix comes..hope it works for you:
"Solution To Strange Performance Issue with Eucon 3.1.2"
http://duc.avid.com/showthread.php?t=354344
  #26
Old 05-10-2014, 03:26 PM
Please see Thread: "Solution To Strange Performance Issue with Eucon 3.1.2" it may help
  #27
Old 05-14-2014, 07:59 AM
Xill Xill is offline
Location: Planet Earth, Milky Way Galaxy, Observable Universe
Why don't AVID make EUCON open an source software?
None of the updates we asked for have been made in over 2 years, we still cant even copy/paste/drag EUCON command from one softkey to another.
  #28
Old 05-14-2014, 09:44 AM
TimNielsen TimNielsen is offline
Supposedly this terminal command will disable App Nap on the entire system. Since I'm not on a laptop, I don't want App Nap on at all, so I ran this.
defaults write NSGlobalDomain NSAppSleepDisabled -bool YES
To enable again, the terminal command is:
defaults delete NSGlobalDomain NSAppSleepDisabled
Use at your own risk, I didn't write these, just found them recently on the web.
  #29
Old 05-14-2014, 09:46 AM
Also, you'll have to restart apps, or better restart the machine to see it take effect. You can open Activity Monitor, and in the Energy page, there is an App Nap column, and it should now read 'no' for every running app.
Tim
  #30
Old 05-14-2014, 12:16 PM
Sorry Tim.
Please do *not* do this as this is Global for your machine.
See my above solution and look at it carefully...Users should not modify things in NSGlobalDomain without knowing what they are doing.
My solution causes a modification *ONLY* to the EuControl domain...and it will work..but never do something like this from a simple web search...even my solution. I want Avid to incorporate this into a fix that is vetted by their QA.
I will return to the shadows... ;-)
.. just clarifying why modifying this setting in NSGlobalDomain is a bad idea:
Imagine that running on your machine there are other apps and processes that currently being "limited" by AppNap when they go in the background ... now you turn it off for all of them (NSGlobalDomain). When you fire up PT (or Logic etc) in the foreground these other apps and processes are no longer forced to go into a "limited" state and they now compete with your DAW.
Eucon Windows BUG: some windows r stuck in background when Eucon running. TuckerMix Artist Series 12 07-08-2014 01:37 PM
10.3.7, 11.0.3 and Mavericks...what to do Mr.Kite Pro Tools HDX & HD Native Systems (Mac) 4 12-26-2013 11:00 PM
Updated Eucontrol to 2.7 and upgraded to Mountain Lion 10.8.2. Eucon now broken. Focuret macOS 0 03-08-2013 09:21 PM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
Alert - EuCon 2.5.6 is only for Pro Tools 9 and EuCon DigiTechSupt Artist Series 11 02-24-2011 10:25 PM
