Need help with weird plug-in error
Hello everyone -
I am having problems getting my (most) of my plugins to open. When I do a search on this error code I can't find anything on it. Can someone please help and offer some advice? I would appreciate it!! THANKS!! The error I get says "The plug-in could not be made active because an AAE error encountered. AAE error -7065 was encountered" Here is my system info - iMac: (24-inch, M1 2021) Chip: Apple M1 Memory: 16GB macOS Monterey - version 12.2.1 Pro Tools - Version 2021.12.0 |
Re: Need help with weird plug-in error
Which plugins are you referring to? It is a know problem with the plugins in the Avid Complete Plugin Pack. Also be aware the macOS Monterey is not yet certified for Protools or any of their plugins. That is not to say it does not work as many folks here have it running with minimal issues. Many 3rd party plugins have been updated to work with Monterey and the M1 Apple Silicon but not all. Avid is traditionally behind in keeping up with Apples annual OS update, so you'll just need to wait a little longer. Recent post by Jeffro at Avid indicate that the plugins will be updated within days, not months. However, not word as to when Protools will be compatible with Monterey.
Please also not that the current version of Protools does not run as a native M1 Apple Silicon application. It runs through Rosetta2, a interim code translator for Intel code.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
I think Obsidian is right. Monterey plugin incompatibility.
I googled: AAE error +7065 …and seems like you're not alone. (Notice the plus sign. In searching, minus sign means show results that do not contain, whereas plus sign means; show only results that contain.)
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Obsidian and Ben -
Thank you very much for the help and insight!! I certainly don’t need Monterey running - If you were to suggest a “working” macOS. for Pro Tools 2021.12.0 - what would you go with? Thanks again!! Sean |
Obsidian -
The ones that give me that error message below are too many to list - but all of them are from each of the sub categories (i.e. EQ, Dynamics, Pitch Shift, Reverb, Delay, Modulation, Harmonic, Dither, Sound Field, Instrument and Other) - so in each of those, there are many of the plugins that give me that error below. Should I uninstall all plugin's are to re-install? Quote:
The issue is that your 24" iMac M1 probably shipped with Monterey. Protools is certified up to Big Sur at the moment. Normally I would suggest downgrading to Big Sur as that is the OS at the time the 24" iMac M1 was released. However, there is a recent thread where someone is claiming that you can not downgrade such an iMac if it shipped on or after October 2021. I am still waiting to see if someone can confirm this claim.
Obsidian Dragon
Obsidian Dragon
Sadly - after a very long battle of many attempts last night - I can confirm you cannot back rev out of Monterey to Big Sur or any others.
EQ: 304E, ff D-2 1-2 band (mono), ff D-2 4 band (mono), ff D-2 6 band (mono), Pultec EQH-2 (mono), Pultec EQP_1A (mono), Pultec MEQ-5 (mono) Dynamics: 304C, BF-2A (mono), BF-3A (mono), Fairchild 660 (mono), ff d3 compressor+ limiter (mono), ff d3 compressor/limiter (mono), Impact, Pro Compressor (mono), Pro Expander (mono), Pro Limiter (mono), Pro Multibad Dynamics (mono), Purple Audio MC77 (mono), Smack Reverb: Reverb One (mono), Reverb One (mono/stereo), ReVibe ll (mono), ReVibe ll (mono/stereo), Space (mono), Space (mono/stereo), Delay: Moogerfogger Analog Delay (mono), Reel Tape Delay (mono), Tel-Ray Delay (mono) Modulation: Moogerfogger Lowpass (mono), Moogerfogger Phaser (mono), Moogerfogger Ring Modulation (mono), Reel Tape Flanger (mono), Voce Chorus Vibrato (mono), Voce Spin (mono), Voce Spin (mono/stereo) Harmonic: Eleven MK ll (mono), Eleven MK ll Cab (mono), Pro Subharmonic (mono), Reel Tape Saturation (mono) Other: Pro Multiband Splitter (mono) |
Meant to say - I REALLY appreciate everyones time here
Weird Plug-in Instument Routing Bug | Dizzi45Z | Pro Tools TDM Systems (Mac) | 3 | 06-08-2010 10:13 PM |
----- Plug-ins Automaticaly Linked!! WEIRD!! -------- | sapi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-03-2007 10:51 AM |
Weird feedback loop when using certain plug-ins. | Rodgre | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-13-2007 01:35 PM |
weird scrambly plug-in name problem | Tgrokz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-31-2006 06:46 PM |
Weird problem with gate II plug-in | Paul Maunder | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-13-2005 12:13 AM |
