Old 03-10-2020, 01:51 PM
Davidwilson Davidwilson is offline
Default Core Audio
Hey All
I am on Windows 10 running the latest PT Ultimate.
Does anybody know how I get audio from apps such as Spotify to run through Core Audio. I could do it on my old Mac in older versions.
Thanks in advance.
Old 03-10-2020, 02:14 PM
origringo origringo is offline
Default Re: Core Audio
Hey man,
Core audio is a Mac only thing. On Windows you'd be looking for the ASIO driver or software controller of whatever interface you're using. Might have to refer to the manual on exactly how, but it should be possible.
Old 03-10-2020, 03:22 PM
The Weed's Avatar
The Weed The Weed is offline
What interface do you have? Some manufacturer's drivers are multi-client and allow your interface to be used for Pro Tools and Windows sounds/audio, others don't.
Best practice is to only use your interface for PT and your onboard soundcard for Windows sounds/audio. But, if your interface does allow it, look in Control Panel>Sounds to default your interface.
I run my onboard soundcards - I have 2 computers - into my RME UFX, which also allows me to have their output available in PT. Others use an optical cable into their interface as most modern onboard soundcards have an optical connection.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 03-10-2020, 04:20 PM
LDS LDS is offline
Are you using Avid HD hardware? I could never get it to work with system sound under windows 10. I just assumed there is no ASIO compatible HD drivers available like there was with TDM systems.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 03-10-2020, 08:28 PM
PT Native and Digi 192 interface.
On may if would see the Native card no problem, on Windows 10 nothing shows up under settings/ system/sound.
Old 03-10-2020, 08:44 PM
JFreak's Avatar
JFreak JFreak is offline
Which release to be exact? I believe only 1809 is supported, not newer ones
Janne
Old 03-11-2020, 09:54 AM
Sorry not sure what you are referring to re: 1809?
Old 03-11-2020, 10:01 AM
JFreak's Avatar
Compatibility info here. But my bad, it seems 1909 is supported with 2019.12
Janne
Digi 002-using FW & core-audio drivers to output audio to mac WITHOUT using ProTools DaveZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 04-12-2012 12:53 PM
No audio from Apple Apps. Core Audio problem? Armando Pro Tools TDM Systems (Mac) 10 10-23-2006 06:03 AM
Pcie core + Core audio + Tiger, does it work? fantomaz Pro Tools TDM Systems (Mac) 0 12-21-2005 01:04 PM
Problems w/Core Midi and core audio MBox 6.1 letrev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-03-2003 01:43 PM
Will the core audio driver enable audio units ? linpaws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-16-2003 02:01 AM
