bus lead vox
Whats the best way to complete this task?
I want to bus the lead vox track to an aux track and compress and reverb all at once, but on the reverb I would like to eq the wet signal only!!!! |
Re: bus lead vox
on the vocal track use a send to bus the signal to an aux. on the aux setup your compressor, verb and eq. on your verb make sure to set it for 100%. Your result should be a compressed and eq'd verb with no direct on that aux.
Re: bus lead vox
bus the vox to an aux track where you put comp on, and a send to another aux track where you put the reverb on (100% wet) wich you EQ there, so only wet signal is EQ'd.
greettzz. |
Re: bus lead vox
This is my understanding correct me if I am wrong |
Re: bus lead vox
This is my understanding correct me if I am wrong <hr /></blockquote><font size="2" face="Verdana, Arial">I think you got it right. Doesn't make sense to me either [img]images/icons/confused.gif[/img] |
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error | EricMulhern | macOS | 1 | 11-20-2011 05:39 PM |
emu xl lead in pt8 | geeball | MIDI | 1 | 05-22-2010 07:48 AM |
xl lead in pt 8 | geeball | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-18-2010 09:04 PM |
Help!! My pencil must be out of lead | defretman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-12-2003 12:52 AM |
LEAD IN or LEAD OUT error when finishing BAKs | Alécio Costa | Pro Tools TDM Systems (Mac) | 1 | 02-22-2002 08:25 PM |
