Old 09-22-2021, 05:29 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Default UBK-1 AAX DSP not showing up in Hybrid mode.
After reading about Space not being available as AAX DSP within the Hybrid Engine, I discovered that my UBK-1 wasn't showing up as AAX DSP either. I recently installed the latest version (1.5.3) from Kush and believed that was the problem. I reinstalled the latest version and still no AAX DSP. Found my version 1.2.6 installer, installed that and there was my AAX DSP once again.
I should also mention it wasn't showing up in classic HDX mode neither. I don't know if this is a Windows only issue but I thought I would bring this to everyone's attention. I did start a support case with Kush.
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 09-23-2021, 05:24 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Default Re: UBK-1 AAX DSP not showing up in Hybrid mode.
I remember the Clariphonic was updated to MKII version. I can't see compatibility on the Kush site which is a bit of a shortcoming.
Looking at the release notes for the UBK-1 it says it was rebuilt from the ground up.
UBK-1 - Release Notes
1.5.3
Oct 14, 2020
- Rebuilt the DSP from the ground up to allow for Logic Pro X 10.5 and Catalina compatibility on Mac, and machine authorization on Mac and Windows.
- As a result of the new framework, many old lingering bugs may now be a thing of the past.
IMPORTANT NOTE FOR PRO TOOLS USERS ON MAC
- There is a known issue in this release which causes the Cmd+opt+ctrl+click shortcut for enabling automation parameters in Pro Tools to instead zero out the control. A fix is in the works, but for now you'll need to use the 'auto' menu on the plugin window to activate parameter automation for the plugin.
1.2.6
Feb 2, 2018
- Addressed an annoyingly persistent "newer version is already installed" error when installing UBK-1 on Mac OS.
1.2.5
Jan 30, 2018
- Fixed a file structure error which caused total AU failure on certain Macs with Solid State Hard Drives.
- Fixed an issue that caused UBK-1 to fail on Mac OS 10.13 (High Sierra)
- NOTE: UBK-1 AAX will be locked at 1.2.4 until further notice.
1.2.1
Sep 10, 2014
- Fixed occasional odd distortion when Pro Tools allocated DSP cycles in a manner which could reasonably be considered 'innacurate'.
UBK-1 was first released on November 20, 2012 and the records of specific changes prior to version 1.2.1 have been lost to the winds of time. Rest assured they were all 100% necessary, and never needed any kind of additional fixing for any reason whatsoever. (Don't quote me on that... -dev)
I recall Greg took over the coding himself after it was previously done by a third party? Maybe he never implemented the DSP side?
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 09-23-2021, 05:11 PM
abc1mce2's Avatar
This is the email I received from Kush today.
Hi Eric,
Kush tried and then abandoned AAX-DSP development years ago. So yes, the last version that contained AAX-DSP was 1.2.6, but again, discontinued years ago.
So I guess 1.2.6 was the last version that included AAX DSP.
Bricasti M7 (2)
Lexicon PCM96
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 09-24-2021, 05:21 AM
martthie_08 martthie_08 is offline
The bigger issue with this is that old sessions with UBK-1 as AAX-DSP will not load / recall the settings with the newer native version.
HTML code is On
System Usage showing <10%, Activity Monitor showing >110%. What is going on?? colliderman Pro Tools 2020 13 06-17-2020 01:49 PM
New s1 not showing up twistedinsane Avid S1, S3, Dock and Control App 11 05-18-2020 03:09 PM
PT 12 and BFD 3 -not showing up jroither Pro Tools 12 5 09-29-2015 04:14 PM
Need some help - I/O not showing up right. lexaudio Pro Tools 10 4 01-01-2013 10:53 AM
3rd 192 not showing up deerock Pro Tools TDM Systems (Mac) 6 03-24-2002 10:27 PM
