Midi ghost notes
My current system is as follows: 003 with a Yamaha Motif ES8 hooked up via midi. I believe I have everything configured properly but am hearing odd notes on occasion, seems to be random. When I am tracking or playing back a simple midi track, I randomly hear a note that was not played. Usually it is the lowest midi note...
Local control on the keyboard is off while midi thru is enabled in PT... any thoughts? I've tried everything I can think of (Different midi cables, diff sound module, etc....). Thanks for any advice, going crazy trying to solve this problem. Current setup: PT 8.0.1 with the update for eleven rack installed 003/eleven rack (usb)/trigger finger (usb) Mac os 10.5.8/8G ram/8 core 2.26ghz Playback engine: 128 samples/5 cores for RTAS/CPU usage 85% |
Re: Midi ghost notes
This is OT, but I am curious why you are using these settings:
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
seems to work well with my setup...system usage to a minimum...
Problem solved....bad midi ports on the 003....thanks everyone...
003 causing midi ghost notes | thisistruth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-11-2010 09:22 PM |
Transport causing midi ghost notes.... | thisistruth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 09-07-2010 08:02 AM |
002 ghost MIDI notes | Thuneau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-16-2010 02:30 PM |
MIDI ghost/duplicate notes problem...HELP! | vocalvoodoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-02-2005 08:12 AM |
stuck/hanging notes and ghost notes | PatrickD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-16-2005 01:30 PM |
