Old 05-23-2005, 02:56 AM
Joris de Man Joris de Man is offline
Default Controlling tracks via Midi on TDM?
Hi Guys,
Strange question maybe, but here it goes:
I use my PT|24 Mix setup as a mixer; I work a lot with midi and all my synths come in thru an Adat bridge and a 1622. I've basically created a session with lots of aux tracks, with synths coming in one each of those so I can have plugins (analog channel, EQ) on them as well.
I sequence using Nuendo on a PC and so whenever I want to record any of my hardware synths I take an ADAT bridge output from the TDM setup and record it via my audiointerface on the PC (an RME card).
What I would like to be able to do is mute/solo some of those auxchannels via midi; currently I have to switch between the mac and the pc to do this, but it is rather longwinded sometimes since they're both on a KVR switch.
Is there a way I can solo/mute channels via midi without having to get a dedicated control surface for protools? All I want is the abillity to send/receive midi messages so I can create a midipatchbay in Nuendo to control those messages so I don't have to switch back and forth..
Any ideas?
Cheers,
Joris
MIDI Controller (Roland Juno D) not controlling Midi Featherstone Pro Tools 10 3 07-25-2013 05:59 PM
Controlling multi instrument tracks with single MIDI track? MotifMan Virtual Instruments 10 07-21-2012 01:08 PM
002 Not Controlling Tracks SDC_Studios Pro Tools 10 1 02-03-2012 11:40 AM
Multiple MIDI Tracks controlling one Instrument Track's MIDI daniel.yengle Tips & Tricks 3 05-04-2011 03:27 AM
Controlling levels for several Reason Midi tracks into PT6.9 polaredit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-17-2007 04:29 PM
