Avid Omni Input / Output levels
Hi all,
Maybe a dumb question but I just couldn't find the answer anywhere: When I output a signal via the Avid Omni outputs and use the inputs to record it back in again the input level is around 5 dBu lower. I uses a cable out from the output straight into the input. When I use the output level trim... and add 5 dBu there the signal level which comes in is the same... but should I always do that? The reference levels are: Output > Line (+ 24 dBu) Input > Line (+ 4 dBu) Thanks in advance for your kind answer! |
Re: Avid Omni Input / Output levels
So you have a track recorded then you send it back out through the omni back into the omni. Just curious why are you doing that. do you want latency or something.
My best goes is that its your input output levels +4 -10 settings or in your using the 1/4 inch monitor outs 1/2 I think they are +10 for those. My numbers could be off but that is most likely whats happening. Sometimes crappy cables will lose volume as well. |
Normally I have an outboard compressor or eq in between the output and input and noticed that the level is lower when I bypass the gear... so I tried it without any outboard in between en noticed a clear difference in the level of the input against the level which I output.
I have connected a DB25-XLR DigiSnake Cable to the outputs and from there a XLR to TRS. I'll try another cable this evening. |
Also I don't understand why the output is +24 dBu and not +4 dBu like other Avid I/O output cards (i.e. Avid I/O 8x8x8)
Because you are supposed to run Monitors directly from it.
+24dbu is for console/line...+10dbu setting is for connection to monitors...
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
Hi guys, thanks for the kind help!
I dug a little deeper in the issue and found the following: I knew the Omni has the following settings: Input: +4dBu (Pro) and -10dBv (Consumer, prosumer) Output: +10 dBu (Speaker level) and +24 dBu (Line level) and the other Avid I/O have: Input: +4 dBu or -10dBv Output: +4dBu or -10dBv But why the difference between those 2??? Probably the +24 dBu is at 0 dBFS and +4 dBu is at -18 dBFS but I'm not sure. please correct me if I'm wrong?! Anyway seems like the Omni is not really useful to connect outboard as in insert as you don't have standard +4dBu outputs... unless you correct output via output level trim, but I'm not sure if that's good practice?! I hate it to correct the output by +5 dBu, I'm not sure if by the correction I made I have now +4dBu at -18dBfs and if I will lose something?! Anyway this is all very confusing |
Could that +24dBu mean +4dBu with 20dB headroom?
yes that could also be possible
anyway, I'm off to a shop to buy a true rms meter |
Perhaps you're overthinking it? None of the other Avid "HD" interfaces are intended to directly drive active monitors (or amp + passive)...you would generally come out of the interface into some type of monitor controller. However, the Omni has a built-in monitor controller, capable of of up to 7.1 monitoring. Therefore, the outputs can be individually configured to operate at +10 dBu (Speaker level) or +24 dBu (Line level) depending on your needs. Instructions can be found under the Analog Output (OUTLVL) section on Page 42 of the Omni Manual...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Digidesign 192 Analog I/O with Avid Input, Output and AES DB25 Breakouts | N1h1l1ty | Buy & Sell | 5 | 09-04-2014 10:02 PM |
HD Omni low input levels | idris | Pro Tools 10 | 6 | 02-25-2013 03:02 AM |
HD Omni output levels and PPMs | idris | Post - Surround - Video | 8 | 07-18-2012 03:14 AM |
Levels lower on output than input | wipeout33 | Pro Tools TDM Systems (Mac) | 16 | 04-07-2008 10:27 AM |
matching input and output levels | ira ostrowski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-09-2003 02:25 PM |
