C24 Talkback Dim is Mute!
The most problematic issue concerning our C24 is that the talkback (built in mic) almost totally mutes the monitors, so there's no way to hear people talking back to the producer thru the monitors. This is unheard of in any other console. Is there any way to control the amount of dimming when using the talkback? Izhar |
Re: C24 Talkback Dim is Mute!
Try taking your finger off the talkback button! The talkback function is for talking.. not listening. If it didn't dimm when being depressed then you would get a tremendous feedback in your control room monitors.
Thanks for the advice...
The problem is that doesn't dim but almost mutes the sound. When communicating with the artist in the recording room, you have to know when to stop talking and listen to what he/she has to say. Right now, there's no way to tell when the artist wants to talk back. To make a long story short, no other console dims this much. Digi, please answer. Izhar |
Engineer: Okay, let's do that one again, over.
Artist: Copy that, over. |
I agree and also it would be nice to double click it and have the talkback on permantly when you want a longer chat, like some other consoles.
------------------ Bye Dave www.indentmusic.com.au |
If you hold the dim button down for a couple of seconds it allows you to decreace the amount of dim down to -6db which helps hugely, as it defaults to -20.
This worked for me, Good Luck, Mark |
This is the correct solution--nice call Mark.
Oooh, Ooooh, can this be set on the Control 24 as well?
I'll check utilities but I don't recal seeing it there, just Internal, External, whatever. No DIM settings. Hold down? Probably not on the old board huh....?
Shorty: Table Syrup Records Mac Pro 5,1 3.33 GHz Hex, 32GB EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23" OSX Sierra Pro Tools HD 11.2.2 Waves IOS, IOX, STG2412 Extreme Server (x2) Logic Pro X, DSP Quattro, Final Cut Pro X Waves Mercury+SSL+AbbeyRoads Trident S65 with embedded US-2400 Live: 2012 Mac Mini, Dual SSD, i7 2.4, 16GB Win 10, OSX Sierra LV1, MRSG Hardware from above (same gear) Dual Dell P2418HT Touch Screens Waves Icon X (x2), M, with Screens Custom enclosure |
This is a feature of the new C|24 not the old Control|24...time to upgrade!! :)
Send mute/solo follows track mute/solo pre-fader | Roger_Jam_Jet | Windows | 3 | 09-24-2017 01:59 PM |
Source Talkback AAX gets auto talkback | MIKEROPHONICS | Post - Surround - Video | 0 | 11-20-2013 08:15 AM |
Mute Region or Mute Automation | Jeremy Mix3000 | Pro Tools TDM Systems (Mac) | 9 | 01-22-2007 07:53 PM |
Can talkback 'pad' instead of mute? | lefty | ICON & C|24 | 2 | 07-03-2002 07:50 PM |
Talkback- Mute instead of Dim | bairtracks | ProControl, Control|24, Command|8 | 3 | 06-07-2001 08:28 AM |
